First post, by Marmes
- Member
Hi!
I've just assembled a ss7 system with a FIC PA-2013 with PCB 2.1, I have the JI4333 bios installed, an AMD K6 III+ set at 2V and 550Mhz, 128mb ram PC100. isa SB16 sound card, isa MQ mpu401, Ali USB card, and realtek 100mbps lan card, on PCI.
I also have these cards:
1-voodoo3 3000 AGP
2-Viper 770U tnt2 ultra AGP
3-Matrox G400Max AGP
4-Kyro II AGP
I have some issues that I just can't understand or know how tos solve them.
Hre goes:
1-When I set my pc with fsb at 100mhz, with any multiplier, voodoo3 does not start, but computer starts and nothing happens(black screen, no monitor activity). If I set fsb to 66mhz it starts and does everything normal. I checked the card with PC-Check, memory, etc and all is fine. But at 66mhz fsb cpu won't go beyond 396Mhz. Does anyone have a similiar configuration? How do I set the AGP to 66Mhz and FSB to 100Mhz in these motherboards? Is there any trick or jumper settings that are not documented?
2-All the other cards run well, install drivers well at 100mhz fsb configuration except Riva TNT2U, locks the system when running Unreal. I guess tnt2 must be a driver configuration.
3-Kyro and Matrox just run fine.
Can anyone help me with the voodoo3 situation? I'm getting a bit desperate.
Thanks!
