Reply 80 of 221, by James-F
- Oldbie
Yes, the SB 1.0 1.5 and 2.0 has the same simple 3.2kHz low pass filter as the SBPro (or should I say the other way around).
You can listen to the GODS track on the SB 2.0 HERE or HERE.
It is only on the SB16 Creative introduced the dynamic brickwall filter, and it sounds different to the SBPro.
DOSBox emulates the SBPro filter even in SB16 mode.
The sound of the filter is all part of the nostalgia.
You are searching for 0805 (2012) 4.7nF SMD Capacitor.
Like THIS ONE for example, which seems to be the most reliable.
EDIT: 6.8nF will be even more accurate.
PS.
It is "Into, the Wonderful". 🤣
