First post, by keropi
Hiya!
I acquired this TSENG ET4000AX ISA vga:
Anyone knows what the 3 jumpers do? 😕
TIA for any help/ideas! 😊
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 1 of 3, by PhilsComputerLab
Had a look on th99, but I'm sure you already checked.
One jumper is always for IRQ2 enable or disable. There might be one for putting the card into 8 bit more. Or one for Wait State or Turbo. Mine has DIP switches to set refresh rates also.
I can only guess, but the jumper at the bottom near the ISA is likely the IRQ jumper. It's usually always closed.
Reply 2 of 3, by keropi
I could not find anything specific , I guess I'll have to do some testing 😀
Thanks for the help Phil
Reply 3 of 3, by PhilsComputerLab
Yea some of these cards are not documented. What I do is do my research before buying 😁
Also note the many jumpers that don't have headers! Who knows what things you could change.
That's why I like the Diamond Speedstar 24x so much. It's well documented.
