Dosbox help
First post, by medieval
I am running win 7 I am having trouble at the prompt. I am trying to play Wolfenstein 3d, the first game i ever bought. I put the game in
C:\ ProgramFiles (x86) wolf\ wolf3d-v11-vgus I can't get it to this the directory It's has been so long that I used the prompt. Maybe I am putting a space where I don't need one, backslash, etc Please type in exactly how I should type to get it to work. Thanks
Reply 1 of 20, by Jorpho
medieval wrote:
I put the game in C:\ ProgramFiles (x86) wolf\ wolf3d-v11-vgus
That doesn't make any sense. Perhaps you can take a screenshot?
You should follow the 60 Seconds Guide. If that is too complicated, try a frontend like D-Fend Reloaded.
If that is still too complicated, you can buy the game at GOG.com in a form that is pretty much guaranteed to run on your computer without any problems. It is a little bit expensive, though.
https://www.gog.com/game/wolfenstein_3d_and_spear_of_destiny
Reply 2 of 20, by collector
You should not put these old games under a systems directory. Put it in a folder that you have full write permissions, say
C:\OldGames\Wolf
Part of your problem is using a path with spaces in it. Either use no spaces or enclose the path in quotes. Also note that under your mounted folder you should follow the old DOS 8.3 naming convention.
Also, follow Jorpho's advice and use the 60 Second Guide.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 3 of 20, by medieval
So I looked at 60 second guide and changed my directory, I typed in what I was supposed to and I got "Drive C is mounted as local directory C:\oldgames\wolf3d\. How do I play it? What did I do wrong now?
Reply 4 of 20, by Jorpho
Perhaps you should keep reading until the end?
Y'know, in general people are much more likely to help you if you provide some indication that you are already capable of following instructions.
Reply 5 of 20, by keenmaster486
Why do you assume you did something wrong?
You need to brush up on the basics of how a command line works.
World's foremost 486 enjoyer.
Reply 6 of 20, by medieval
your right i just skimmed over it, sorry. After years not using prompt I get super bored reading. I should have added that I get the exe but can't play it, I will read all the way through. BTW If people want to play an old game they can just go to myabandonware.com and play hundreds of old games directly on their browser. I just thought is would be nice to have it on my system. Thanks again.
Reply 7 of 20, by lightmaster
Bored?
No abandonware.
Buy it.
You're welcome.
Reply 8 of 20, by medieval
I get the EXE but still can't run it. I don't need play it, just thought it would be fun. Yes,Lightmaster, Bored to death. I developed a virtual aquarium, actually a few of them. After that I lost all interest. I guess from your point of view, you can't understand my point. BTW check out my aquarium if you have time let me know what you think. https://www.youtube.com/watch?v=MqDtusJ9lCw
Reply 9 of 20, by Jorpho
Nah, aquariums are boring.
Reply 10 of 20, by medieval
can you imagine a DOS aquarium? Mine is pretty real and the graphics are very clean
Reply 11 of 20, by lightmaster
Fishtro still rules!!
Oh and BTW it's not abandonware!! ;·))
Reply 12 of 20, by ripsaw8080
Rank DOSBox Author
DOSBox Author
El-Fish?
Reply 13 of 20, by gdjacobs
No fishbowl unless it's in your retro computer tower, or inside a CRT tube with a failed flyback transformer.
If that's what you've got, then give us mowr!
https://cdn.instructables.com/FVH/GPOB/F3KLNV … NV83.MEDIUM.jpg
http://www.tomshardware.co.uk/cebit-2003-day- … iew-7220-2.html
Reply 14 of 20, by medieval
Have you even see mine. I mean the gills, eyes, mouth, fins, etc, etc work. When you feed the fish ( I added that after the youtube vid) the food goes into fish's mouth. the crab will chase fish if they get to close to him, not to mention you can spear the fish so it's like a came plus a fish tank. Come on dude DOS is dead.
BTW The reason i could not play wolfenstein must be a problem with the software I downloaded, I tried another game I had back then, called Commander keen4e which works great.
Reply 15 of 20, by Jorpho
Yet here you are, making a DOS aquarium.
Aren't you bored of this place yet?
Reply 16 of 20, by medieval
I did not make a DOS aquarium. By bored I meant reading up on the prompt is out of date what's the point? Don't take it so personally. I was just here because I wanted to play Wolfenstein again, It was my first game, The games now are 100 times better.
Reply 18 of 20, by keenmaster486
If all you wanted to do was play Wolfenstein again and you don't give a soggy towel about anything else, then this isn't the forum for you.
Command-line prompts are FAR from out of date. That's a foolish error if you think that. Just try to develop software or use Linux without using the command prompt.
