First post, by dj_anubis
My first question' does anyone knows what are the controls once you stopped here?
2nd question
when i play pitstop 2 it looks like this on dosbox:
but in moby games i found this image which says "Gameplay (note the alternate CGA palette and background color)"
someone knows how to get this colors from the 2nd image?
Reply 1 of 3, by VileR
Doesn't look like the intended colors. In fact this is what you'd get if the *composite* graphics (selectable by hitting "1" after the title screen) were somehow running in mode 4 (320x200 palette 0 background 1) instead of mode 6 (foreground 0xA) as they should be, and viewed on RGB instead of a composite display.
That's an old screenshot from 1999; guess it was taken from a not-quite-CGA-compatible VGA card or so.
Reply 2 of 3, by dj_anubis
Thank you
Reply 3 of 3, by Stick
Pitstop II manual
[Edit: attachment removed. Game documentation is copyrighted material. Do NOT post or link to it here.]
