First post, by BSF2015
What is the program to make a new Pacman game???
It's called programming language
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
Pacman game making tutorial for DOS??
Do you even know how to program?
World's foremost 486 enjoyer.
I don't know, so give me a tutorial about making a Pacman game on DOS
That's like asking for a tutorial on speaking French. Or a tutorial on building an 18th century carousel.
You can try looking at how someone else did it: http://www.deathshadow.com/pakuPaku (game archive contains source code)
wrote:I don't know, so give me a tutorial about making a Pacman game on DOS
There are many resources across the Internet that will teach you much better than here. What you need is a tutorial on basic DOS game development.
Google is your friend.
Coming here unannounced and demanding that we write a tutorial on DOS game development, which is a very complex subject and would require a lot of work to explain properly, is bad enough. You're not only doing that, you're also demanding that we give you specific instructions on how to make a specific game, i.e. PacMan, which would require even more hard work. Don't just expect someone to do that for you. We can always point you in the right direction, but writing specific and comprehensive instructions? No. That's not what this forum is for anyway.
This is like asking a stranger to write you a calculus textbook and then do your homework assignments as examples.
A start might be to get QBasic and look at the example program called nibbles.bas which is usually bundled with it iirc. It has similar functionality to what a PacMan clone might require. You will need to learn some BASIC https://en.wikipedia.org/wiki/BASIC, which most programmers have no doubt come across in their lives so its a good start. Probably easier to write a PacMan clone from scratch, but nibbles framework may give a nice basis/engine to build on or fudge about with to get some "wakka wakka wakka wakka ... WOOO WOoo wooo" action.
Apologies for the bad PacMan phonetics there, couldn't resist.
Where's the Pacman MS DOS Source Code??
Yes, start with ASCII 'graphics'. Text mode games are the simplest to do. Forget about sprites or line drawing. See if you can get a letter 'C' character moving about the basic 80x25 textmode screen using the cursor keys. That's the first step.
"AI Requires Proof That You Are Human"
wrote:Where's the Pacman MS DOS Source Code??
On the Internet. 😜
Someone out there has probably written a game like Pac-Man for MS-DOS and has provided the source code, and you can probably find it if you spend enough time using Google with the right search terms.
EDIT: A search for allegro pac-man game source turns up many useful hits. (Allegro is a library often used in making MS-DOS games.)
Never, ever make a public release something based on someone else's code without giving credit to the original author.
Somehow, I got a hunch this kid may grow up to become a new "Gary"
ZZT is your best bet in my opinion. It's old, but it's dos, with a MDA charset display, compatibility is universal, and it has a quite popular OOP language (Sorta) called ZZT-OOP of which numerous tutorials exist.
https://en.wikipedia.org/wiki/ZZT
https://en.wikipedia.org/wiki/ZZT-oop
You however seem to have forgotten that programming a game, even one as simple as Pac-Man is not a matter of a few lines of code and boom. While ZZT makes it easier, it's not going to be a simple task. There is a learning curve, and not a small one either.
wrote:That's like asking for a tutorial on speaking French. Or a tutorial on building an 18th century carousel.
I haven't laughed so hard in ages, thank you.
Heh, thanks. I'm not sure why that suddenly came to mind.
OP - find a copy of this book and read it cover to cover: https://www.amazon.com/Tricks-Game-Programmin … e/dp/0672305070
You'll be well positioned to make your pacman clone then.
wrote:Heh, thanks. I'm not sure why that suddenly came to mind.
I actually googled 18th century carousel pics. Yep, you'd be hard pressed to build one from a tutorial 🤣
wrote:Somehow, I got a hunch this kid may grow up to become a new "Gary"
Who's Gary?
If I'm not mistaken, Mr. leileilol is referring to Gary Accord, previously mentioned in threads such as Re: Virtual Reality Studio/3D Construction Kit games . As I understand it, he has a habit of putting together generally terrible games (sometimes stealing other people's assets, apparently) using game-creation engines and then spamming them wherever he can.
