First post, by Moses
I am running Windows 10.
When mounting my CD-ROM I use the command
mount D D:\ -t cdrom
but when I run DOSBox I get a Windows error that says
DOSBox.exe - No Disk
There is no disk in the drive. Please insert a disk into drive D:.
I have to click on "Continue" or "Cancel" about 5 to 6 times and then DOSBox will finally launch with this message
MSCDEX: Mounted subdirectory: limited support.
Drive D is mounted as CDRom D:\
Any way to not have this Windows message show up?
What does this mean by "limited support"?
