Are you missing -5volt too?
Reply 20 of 57, by brostenen
h-a-l-9000 wrote:
Actually power supplies with -5V have a 7905 built in.
True...
I have been hunting for a solution with that chip.
Something about a coil, a diode bridge, some caps and stuff.
The result will be much more expensive than I want it to be.
Found here:
http://www.frankshospitalworkshop.com/electro … wer_supply.html
The bottom part would work, as a separate diagram, if the diode bridge magically woul work as a polarity reverser.
As I read it and understand diode bridges, it can not be done.
Reply 21 of 57, by Jepael
Yes the circuit you posted is already a power supply itself. It has an AC transformer so it takes mains AC in and steps it down and isolates to safe low voltage levels.
The diode bridges rectify the AC into ripply pulses of one polarity which is smoothed to ripply DC with the cap. So again in this circuit the only thing the 7905 does is that it takes in about -12 volts and regulates it into smooth -5 volts.
So the diode bridges or transformers do not magically convert +12 volts to any negative voltage.
Reply 22 of 57, by SquallStrife
Depending on how much current you need, you could try the ICL7660A, which is a switchmode-inverter-on-a-chip, needing just 2 external capacitors to produce a -12v rail from +12v, or -5v from +5v.
Using it successfully to run a SB16 in my Teradrive, which only provides +5 and +12 from the PSU.
Reply 23 of 57, by PhilsComputerLab
What about modding a 7905 onto the sound card?
YouTube, Facebook, Website
Reply 24 of 57, by brostenen
If I am reading the datasheet right, does that deliver max 20ma? I am aiming at 1.5 amp +. I know 1.5 is overkill, though I need to make shure it does not require heatsink because of heat.
Reply 25 of 57, by brostenen
Theoretically yes.... I see two drawbacks.
One is that -12volt Line is weak. So is there enough left from that line, to power the -12 to -5?
The other is that I would feel bad, about modding such old vintage hardware.
I would rather go with some universal solution, that works on every setup. The biggest problem of all is to convert positive to negative voltage.
I feel that poaitive 12 volt to negative 5 volt is the way to go, as positive 12 volt is heavy these day's.
Reply 26 of 57, by gdjacobs
The answer is to use an inverting regulator. A buck-boost regulator IC would allow you to deliver -5V (this can be adjusted) using a BGA chip and a few passive components.
For example:
http://www.linear.com/product/LTM8049
Reply 27 of 57, by Jepael
brostenen wrote:
Theoretically yes.... I see two drawbacks. […]
Well if AT power supplies had max -5V output of 0.3A to 0.5A, I really don't see the point of making 1.5A and more available.
And do you know how much current does your current PSU provides -12V, and how much your system consumes now?
Modern ATX supplies will provide up to 0.8A.
Reply 28 of 57, by brostenen
Jepael wrote:
Well if AT power supplies had max -5V output of 0.3A to 0.5A, I really don't see the point of making 1.5A and more available. […]
I want to make or be part of the making. Of an universal converter, that can deliver enough extra (nothing like a bit of overkill), and be easy for every user to make and be avaliable to everyone that need such a device. Just like I initially wrote when I started this tread.
Reply 29 of 57, by brostenen
For example:
Allmost fried such a device.
Reply 30 of 57, by gdjacobs
brostenen wrote:
For example:
With butter and onions? Seriously, tales of magic smoke are always good to share.
Reply 31 of 57, by brostenen
Yeah.... I had one such device hooked up, reversing polarity. And connected it to a gnd wire, that led straight into a mobo. High pitch noise and some sparks momentary. It became unbareable to touch and yet it survived. Still stable and holding voltage beautifully. Such a tough little device. 😜
Reply 32 of 57, by Jo22
lm741 darlington
Reply 33 of 57, by BloodyCactus
I knocked out a 7805/7905 schematic. I have not tested it yet ofcourse;
osh park link to gerbers;
https://oshpark.com/shared_projects/r59Tj1Ia
feed +12/GND in, get +5, GND, -5 out. throw some 10uf caps or something on there to smooth it out.
I should probably throw an LED on the +5V output so there is a minor load on the vreg....
Reply 34 of 57, by DNSDies
I'm surprised nobody mentioned this before, but If you're into old arcade games, you might know about a product called the Negatron.
http://www.dimensionengineering.com/products/negatron
It can provide a -5V rail at 500MA for $20.
Reply 35 of 57, by SquallStrife
BloodyCactus wrote:
I knocked out a 7805/7905 schematic. I have not tested it yet ofcourse; […]
That's not how 7905's work.
Reply 36 of 57, by Jepael
Exactly, that's going to burn or something.
Haven't we stated here already many times that an 7905 cannot make -5 from +12, but it can make -5 from -12.
And I think the 7905 pinout is wrong too, 7805 is in-gnd-out and 7905 is gnd-in-out.
Reply 37 of 57, by gdjacobs
I think the 7905 will end up shorted out of circuit as ground is common with your "-5V" rail. Your regulator stage needs to be floated for this to work.
Have a look at the buck-boost regulator I linked. I think it or something similar will suit your purpose.
Reply 38 of 57, by BloodyCactus
its this schematic basically, except with 12vdc and '05 chips isntead of '15.
Reply 39 of 57, by SquallStrife
Yep, and that won't work.
The regulator will only give you -15v with respect to its ground pin, which is at +24v.
24 - 15 = +9v (with respect to circuit ground)
