First post, by boxpressed
I'd like to post some recordings of DOS game music from different GM wavetables that I own. What's the best website for hosting these 1-2 minute recordings?
And what's the best audio format for saving these recordings? Thanks for all advice.
Reply 1 of 11, by Phlum
I usually go for SoundCloud for this sort of thing.
Reply 2 of 11, by keenmaster486
SoundCloud works of course, but the audio quality is low enough that you'll definitely notice the compression.
You could just use Google Drive and post the recordings as FLAC or high quality AAC/MP3.
World's foremost 486 enjoyer.
Reply 3 of 11, by Phlum
Why not do both? Put it on SoundCloud just for listening to, and have download links for your high-quality files.
Reply 4 of 11, by gdjacobs
Opus is the new hotness when it comes to lossy sound compression.
Reply 5 of 11, by SaxxonPike
SoundCloud does allow you to host raw WAV and I believe FLAC is supported. You don't get to stream in this format but you can allow downloads.
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
Reply 6 of 11, by boxpressed
Thanks for all of the suggestions. I've decided to go with MP3 (320 kbps) and Soundcloud for now.
Although I will be starting a new thread for these recordings, here's the first one.
It is the Silicom Wavemaster 64FGP. Although this is not a very common OEM, the AdMOS QDSP 1000 wavetable it uses finds its way onto a lot of inexpensive boards.
Here's Descent: https://soundcloud.com/user-306991531/descent-64fgp
Reply 7 of 11, by PhilsComputerLab
Why not just put the file on your server? At least in Chrome, it should play directly from within the browser?
Reply 8 of 11, by boxpressed
I don't have a server. Also, I'd prefer to keep these off my Dropbox/One Drive/Google Drive, which I use mostly for work. Soundcloud seems to maintain the fidelity reasonably, and I like how I can add comments to note the card and the synth it uses.
Reply 9 of 11, by firage
320k MP3 is a real waste. It made some kind of sense a long time ago, when compatibility was a pressing concern. You're using a lot of bandwidth for a lossy recording; if you can't do ~900k bitrate lossless for all its benefits of bit accuracy including transcoding to other formats, the optimal rate is below 200k and preferably a more advanced lossy format than MP3 (OGG or AAC).
My big-red-switch 486
Reply 10 of 11, by boxpressed
I kind of figured since Audacity rates that bitrate as "insane" or some such. I went ahead and recorded using OGG at the highest setting (10). Maybe I'll switch to lossless if it's not too much of a hassle. When this gets to seem like work, I'll stop.
Soundcloud seems to convert the audio to its own format, so I'm not sure how much that process degrades the audio. But it's okay for now.
Reply 11 of 11, by Phlum
As far as I know, Soundcloud converts the audio to MP3 @ 128kbps.
