Agreed with all above, just adding some extra little bits 😀
SRQ wrote:I have a few questions relating to finishing a project.
Firstly, can you mix and match 30pin ram as long as it's still paired? IE I have 8 slots, if I get 4 4MB sticks can I fill the rest with 1MB sticks?
Yes, but some boards may want larger or smaller modules as the first bank, so sometimes you may need to shuffle a bit.
SRQ wrote:
Secondly, how was old ram compared speedwise? Nanoseconds? Does it make any real difference?
The speed ratings of these modules is the maximum ratings these modules can run at, but if your system is slow enough then it doesn't matter (kinda like a bike and a car are equally fast when going 2km/h).
SRQ wrote:
I can double my 486's cache to 256, will that make any real difference? Doing so would require I strip it from a second 486 board that has a bad bios but I was hoping to repair, would it still work with 0 cache for testing?
It will increase the cacheable area, I don't think it will make a vast difference otherwise?
I think it's more important to at least have more cache then no cache whatsoever.
SRQ wrote:
Finally, two upgrade questions:
Are DX2 processors drop into DX1 systems? This system dates to 1989 (Maybe 1991, hard to tell. Asus ISA-486 board), it's a DX33 system as is. Doesn't have any jumpers for mulitpliers, just a jumper for 24/33 or 50Mhz.
There actually exist drop-in replacements for DX-33, they are called "Overdrive" and made by Intel. You can read a bit about these CPUs over here https://en.wikipedia.org/wiki/Intel_80486_OverDrive
There are also other upgradechips made by(for instance) Kingston.
SRQ wrote:
What's the best ISA video card, and is there any real difference in perfomance? There's no VLB slots on this board, and it currently has an ATi XL24. Is that fast enough that something faster would be limited by the ISA slot?
What the others have said.
If you have VLB or PCI slots, it might be recommendable to use one of those slots for your graphics card, if only because you'll have more options and thus you could opt to use a cheaper solution.
