Reply 14480 of 58568, by einr
- Member
Well, I got this computer for free on a rescue mission today... So I technically didn't buy it but I also didn't find it in a dumpster so I choose this thread 😉 It was rescued from the basement of a building that is about to be torn down. Last minute save, tomorrow it would have been scrapped.
This is an IMC XT/TURBO. It's a generic "turbo" XT clone with CGA, I think it runs the CPU at 8 MHz. Other specs unknown at this point but it has the usual stuff.
The monitor is a Philips CM 8533 RGB monitor which is very similar to early Commodore monitors like the 1084. I believe those were rebranded Philips monitors. Very versatile, it has a SCART input, composite, TTL RGB via a DIN plug and some other cool stuff. Would be useful for almost any 80's/early 90's home computer or console.
Built like a tank. You press two buttons on either side of the case and the hood pops up, very convenient. Check out the size of that PSU!
Right now it doesn't boot unfortunately. The PSU starts up and there are some noises from the hard drive but no POST beep and there's nothing on the screen. Will investigate.
(Also from the same place I got this stuff, all free: two vintage 70's tape decks, a stereo receiver, the first portable CD player Sony ever made, and an ancient oscilloscope)
