First post, by GPA
Hi, everyone!
This is my first post on Vogons, although I have been watching your forum for quite some time already and love it.
I have recently acquired a 486 board that I fail to start. The board powers up and the post card shows a few post codes running, stopping at 0d. I do not know who is the manufacturer of the board, but I assume it is one of the early Intel boards. It has a 486sx-25 CPU soldered on and a socket for an upgrade CPU. Unfortunately I do not own any 5V 486 CPUs to test it with, and I do not have any idea if it is jumpered correct for the internal CPU. Could anyone please help me with identification and maybe finding manuals for this board? I have tried googling the PBA number but it has given no results.
Here are some photos of the board from my google album (unfortunately I have no other photo hosting available with my current internet setup):
Board itself:
https://photos.google.com/share/AF1QipNd2nTCt … mRqN0xvOHRFcE13
the PBA number on the board:
https://goo.gl/photos/6KktaA1yfo3Uuzxy7
CPU type select jumpers (it looks like it is configured for 486DX as printed on the PCB, 1-2 and 5-6 are short, but reconfiguring it for the SX - 3-4 short, others open - didn't change the board's behavior):
https://goo.gl/photos/xFTDo8Kcb9PCNwHM8
CPU speed jumpers (there are no instructions on the configuration on the PCB):
https://goo.gl/photos/A7NQT3rqLzomXgqF6
Chipset/BIOS close-up:
https://goo.gl/photos/1XhzYZaPD6T5C6cD9
I've tried few different FPM SIMMs on the board that proved to be working on my other Intel 486 and Pentium boards, but no matter what memory I tried to install and even with no memory installed the board behaves similarly: few post codes run, stop at 0d. I assume cache setting may be incorrect, or the CPU speed/type. But I think in case of the CPU speed/type mismatch there would be no post codes running. I have no ISA viso card to test the board with, so I used a VLB video card that works in my 386 board, Cirrus Logic 5428 based one.
The oscilloscope has shown that there was generation on both RTC and main clock quartz crystals, everything was within specs. There is no battery onboard the PCB and there is a connector for external battery, that I did not try out, but yet again - could it be that because of the battery there are post codes but no start?
Thank you very much for your suggestions, I could use any help, my ideas are depleted.
