First post, by DracoNihil
DracoNihil
Online
- Oldbie
I've been trying to get this to work just now and everytime I get ingame it either segfaults just when gameplay begins or segfaults right after a few seconds of gameplay. I'm using mainline 0.74 DosBOX from the Ubuntu repositories. I'm not trying to run the 3dFX version that GOG defaults to.
I'm running Linux Mint 17.3 Rosa and my Kernel is: 4.4.0-22-generic #40~14.04.1-Ubuntu
This is what shows up in dmesg:
[94761.353854] traps: dosbox[9662] general protection ip:7f726024bb0e sp:7ffc0baa6b28 error:0 in libm-2.19.so[7f726022d000+105000][95223.034879] traps: dosbox[9696] general protection ip:7f39ada38b0e sp:7ffdcf503078 error:0 in libm-2.19.so[7f39ada1a000+105000]
Here's the contents of my .conf file:
[sdl]fullscreen=falsefulldouble=falsefullresolution=originalwindowresolution=originaloutput=openglnbautolock=truesensitivity=100waitonerror=truepriority=normal,normalmapperfile=mapper-0.74.mapusescancodes=true[dosbox]language=machine=svga_s3captures=~/.dosbox/capturememsize=63[render]frameskip=0aspect=falsescaler=normal2x[cpu]core=dynamiccputype=pentium_slowcycles=auto 7800 105%#cycles=fixed 77000cycleup=100cycledown=100[mixer]nosound=falserate=48000blocksize=1024prebuffer=512[midi]mpu401=nonemididevice=nonemidiconfig=[sblaster]sbtype=sb16sbbase=220irq=7dma=1hdma=5sbmixer=trueoplmode=opl3oplemu=compatoplrate=48000[gus]gus=falsegusrate=48000gusbase=240gusirq=5gusdma=3
ultradir=X:\[speaker]pcspeaker=falsepcrate=48000tandy=autotandyrate=44100disney=false[joystick]joysticktype=4axistimed=falseautofire=trueswap34=falsebuttonwrap=false[serial]serial1=dummyserial2=dummyserial3=disabledserial4=disabled[dos]xms=falseems=falseumb=falsekeyboardlayout=auto[ipx]ipx=false[autoexec]#mount X: ~/ULTRASND411
Unrelated but I also get segfaults while trying to play Quake under DosBOX.
― Κυνικός Δράκων
