In the process of doing a couple of sli builds though very behind at this time but I once had a XFX 780i and it was a royal pain in the ass to "get right". Nforce4, 680i, and 780i boards are ok but you have to sadly earn it or you will get a lot grief especially with the micro shutter thanks to the shit pci-e latency issues with boards equipped the infamous N200 pci-e bridge.
Nforce4 (Intel) extreme heat may as well cook meat but pretty solid after cooling is upgraded (had to drill a large all copper socket A Thermalright cooler to fix the temps)
680i, great overclocking except the cooling is still very poor and neglect kills boards
780i, basically a 680i with a N200 bridge so thermal hell but potentially amazing overclocking if you can replace the cooler altogether preferably with a water block
790i, the best all around SLI chipset for 775 except they are costly, hard to find, and wish that I had one
If any of you have a few copies of "hyper sli" which is a registry hack for older drivers you can get SLI working on a wider verity of boards with AMD and Intel chipsets. There is a hack for modern drivers but haven't tested it.
