Muted Midi
First post, by Rackatack
Hello,
I posted it in a wrong part of the forum, so here am I.
I have a soundblaster awe32 (CT3980) and I'm having issues with midi. The volume of the midi is way to low when I select general midi, it seems muted.
When selecting AWE32 everything works fine.
I have no conflicts with IRQ, DMA, ...
The settings are fine with the mixer
I tried with or without midi daughterboard (Dreamblaster X2 prototype that sounds amazing by the way)
When I try to play any monkey island games, the sound is distorted I tried starting the game and forcing the soundblaster.
But, when I launch the same games in Win98, everything works fine general midi and awe32
Any ideas?
Reply 1 of 5, by Frasco
Hi there...
I also have one and I was just talking about it and although mine doesn't have a wavetable connector, believe me, I know what the hell I am talking about.
For AWE32 General MIDI, you have to do some changes in Autoexec.bat. I'll prevent you: This card is already filled with bugs and doing so will just add more of them !
About General MIDI through your daughterboad ? I don't see any problems, except for "hanging notes" bug (this can be arranged).
Maybe a conflict with ports?
Reply 2 of 5, by Rackatack
Hi Frasco,
Thank you for your reply, I started to have an irq conflict before but was able to address that by checking features in the bios.
I don't have any conflicts anymore, and when dunning "diagnose" everything is detected the way it should, and don't have any "hanging notes" unless i "force quit" the program I'm running.
Reply 3 of 5, by Frasco
No problem.
Now that you said IRQ, you really want to use your card in Port 220h IRQ 5 (default).
You can do it using CTCU.EXE or BIOS.
Rackatack wrote:
running "diagnose" everything is detected the way it should
Does diagnose play MIDI from your AWE32 or from your daughterboard ?
To tell you the truth, I 'm a little lost here.
Last thing I remember was me using a SB16 + daughterboard (from Roland).
My scenario : SB16 + daughterboard (FM port + 330h = no conficts)
Yours : SBAWE32 + daughterboard (EMU8000 port 330h or 620h + daughterboard 330h = ????)
Sorry, none of my AWE32 sports a wavetable connector.
Rackatack wrote:
I don't have any "hanging notes" unless i "force quit" the program I'm running.
"Hanging notes" bug is a different animal! It will manifest in a SB16 in no time, but in a AWE32, it can take hours.
And that's why you are not aware of this terrible thing.
Reply 4 of 5, by Rackatack
A little update on my issue, I think it may be more a driver related issue than a settings issue, it's a PNP card, and everything is detected correctly, and I don't have any issues on Windows
IRQ or DMA issue will more cause a "no sound" issue instead of "faint sound" There is something comming out of the card, but I have to put the volume of my sound system way to loud
Reply 5 of 5, by Frasco
Drivers ? Have you updated Diagnose to 4.05 and AWEUTIL to 1.36 or better ?
Loose canon ! 😀
But this saved me once.
