Reply 14960 of 57774, by TheAbandonwareGuy
- Oldbie
wrote:Today I received mi latest (and biggest to date) eBay haul: All left to right, top to bottom: […]
All left to right, top to bottom:- MSI GeForce GT 440 1GB, nice card with better than usual cooling, small but 1.5 slots wide, it's supposedly silent and cool (two, only one pictured).
- Asus GeForce 8500GT 512MB Silent, relatively small passive cooler, we'll see how it perfoms.
- Sapphire Radeon HD 4650 512MB DDR2 64 bit, usually these cards are 1GB DDR3 128 bit, I wonder how big the perfomance impact will be with such a reduction in memory bandwith, but probably good for a HTPC.
- Asus GeForce 6600LE 256MB, the small brother of the 6600GT, at least it's passive.
- ATI Radeon HD 2400 256MB, it uses a DMS-59 connector for output, fortunately it includes a dual VGA adapter or it will be useless to me.- Creative /Ensoniq ES1370 PCI, it should be a nice card for late DOS games and also a nice substitution to the on-board sound of some W98-XP motherboards.
- Creative CT4810 (Vibra 128, if I'm not mistaken), more or less same as the above (X2)
- Creative X-FI Xtreme Gamer, a bit ridiculous name but a nice sound card with native drivers from XP to W10 (X2)
-Sound Blaster Live 5.1, nice in it's moment for the EAX support, now a challenge just to make it work in Vista and above, nice for an XP machine.- Iwill IDE raid card, it can function with only one drive, making it a good way to add IDE support to SATA only machines, althought I don't know what OS it supports.
- Three CardBus network cards, two wifi and one ethernet, my only CardBus compatible laptop is currently 600 kms away, so they'll have to wait.
- A strange Pinnacle card, for what I gathered it's part of some version of the Pinnacle Studio package, it combines two firewire ports with S-Video, composite and audio output (not input, contrary to what some people believe it's not a capture card), i don't know what kind of compatibility I can expect (no drivers at all, if it works it should be with the OS native support).
- Generic Realtek ethernet cards (like four or five, and I already have some...)
- Firewire only PCI cards, three of them.Now, more interesting pieces for my fellow vogoners:
- Ati Radeon 9800 256 MB with a Zalman cooler (the cooler is going to need some loving).
- Asus Radeon 9600SE 128MB, I found a small socketed capacitor in the box and I'm nearly sure it's from this card, I don't have the equipment to resolder socket mounted components, so I'll try without it and if it doesn't work or explodes, well, that's life.
- Ati Radeon 9550 PRO 256MB, if I remember well the 256MB is the best version, I already have one with passive cooling.
- Ati Radeon 7000VE 32MB, perhaps the lowest form of Radeon, it should made a good sacrificial lamb when I have to test a motherboard with a suspicious AGP slot 🤣 .
- Ati Radeon 9100 64MB, another basic card, this one at least includes a DVI output.- Gainward GeForce 8800GT 512MB, a little surprise: not only it includes the original box (and althought it's obviously used it's in very good visual shape) but also it's a pretty uncommon one slot card (and real one slot, not one-and-a-bit), althought I'll have to be very pressed for space to include any card next to this one.
All in all about thirty cards, with some pretty nice ones, for a grand total of 65€, in fact 30€ for the cards and 35€ for the shipment (30€ was the initial bid, I put a placeholder bid and I win becouse no one else bid). According to the seller, they're untested but "most or all" should work, we'll see.
I'd drop the X-Fi in my main if I were you unless your running a Xonar DGX or something good like that. Pretty much anything north of the Audigy2ZS from Creative makes a good modern sound card.
The GT 440 still makes a nice HTPC GPU (Hell, I use a GT520 inside a decade old 1st gen Quad Core dell as mine)
The silent 6600s in my experience usually don't perform all that great (I have a factory OC'd Gigabyte Silent Pipe 2, closer to GT clocks than normal 6600 clocks)
Nice 8800GT. I've had a chance at a few XFX Alphadog 8800GTs that were single slot but being the owner of a 8800GTX and having limited cash for the hobby I've never pulled the trigger. I've always assumed they would be a cooling nightmare. G92 was not a GPU core that was meant to be single slot cooled.
Also that 9800 Pro is the same revision as mine. Runs exceedingly hot. Make sure to apply some Arctic Silver or another good cooling compound. Also, 2 words: Ram Sinks. Without them you'll be able to simulate the temperature of hell just inside your case...
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
