First post, by mightylaocrahcot
- Newbie
Is there anyone here with experience of this hardware that could help me troubleshoot a little?
I bought the card off eBay 1-2 years ago and had it working when I first tested it. That was some time ago, and I removed it in order to test some other hardware like a bridgeboard. Now when wanting to install it again, it is not completely dead but shows only a black image.
My current system:
Amiga 2000 (rev 6.2 I think)
Kickstart 3.1
A2630 (2MB) with DKB 2632 (40MB)
GVP Impact A2000-HC+8 (2MB)
Indivision ECS
GVP EGS 28/24 Spectrum (2MB)
It also has some ISA cards (SBC, VGA and sound blaster) but no bridgeboard so that shouldn't interfere with the Zorro bus.
I replaced the PSU with a more powerful ATX and tick signal from the motherboard jumper setting.
The VGA to DB9 cable for passthrough I made myself and tested recently with multimeter. This was the same cable that I used when I got it to work the first time.
I assume that the card's pass-through connection should work right away, before booting and loading the GVP software? I can't recall exactly from my previous install, but I don't remember any fiddling around with installing software first and then connecting passthrough cable, so I assume I just connected the cable, booted with image from Indivision ECS through the GVP card and then installed the software.
In that case there must now be some fault with the hardware (amiga or GVP card) or a conflict with other hardware, because now the screen is black from the moment I turn on the switch. It has some kind of signal, the monitor does wake up and goes into sleep mode a couple of times, but eventually stays on.
If booting with the GVP card installed but Indivision connected directly to the monitor, the GVP Spectrum shows up as working in the boot menu. The software installs and loads without errors as far as I can judge.
I tried removing the A2630 accelerator with no effect. I don't remember if it was installed when I tried the first time.
The GVP card has a rather large scratch on the back side, which it had when I got it, and hence also the first time when I got it to work.
(The bridgeboard I have and gave up on (A2386sx) had similar problems. The card showed up as working, software installed fine, but the PC software wouldn't start with some mysterious "Janus.lib not found" although Janus.lib was where it should be, so I don't exclude that I may have some problem with my MB also.)
Any ideas what the problem may be, if it can be fixed and what else I can try?
