First post, by Guest
I'm trying to run Ascendancy with DOSBox 0.63 on my Apple iBook (1.2GHz G4). It's a little slow and could do with a few more CPU cycles but I can't increase it using ctrl + F12 as my iBook uses this combination to eject the cd, and I can't remap the key as it also uses F1 to lower the screen brightness. I can write a config file ok and changed the value in it from 3000 to 4000 and Ascendancy ran perfectly until I rebooted, at which point DOSbox stopped loading the dosbox.conf file which it had been doing perfectly well not 5 minutes earlier. I've followed all the instruction in the readme but it still won't load the dosbox.conf file with 4000 CPU cycles (Which is a bit of a bugger).
Any help would be greatly appreciated
Reply 1 of 10, by MiniMax
Rank Moderator
Moderator
Do a search on your harddisk for that config file. How many do you see? Where are they? Inside the main DOSBox installation directory? With the game? Which one do you want to use? How do you start DOSBox?
_________________
Reply 2 of 10, by Guest
I've only got one copy of dosbox.conf and it's in the same directory as dosbox.app, ~/Applications/DOSbox/ with Ascendancy being in ~/Applications/ASCEND/
I usualy start DOSbox from the application dock at the bottom of the screen.
Is there another version of DOSbox I could use that is started from the terminal? The .app version won't let me do that. Could that be the problem?
Thanks for your help
Reply 3 of 10, by MiniMax
Rank Moderator
Moderator
Hmm... Can you rename your dosbox.conf to 4000.conf (not copy, rename!) and then launch DOSBox all by itself? Next, from the DOSBox Z-prompt do this:
Z:> config -writeconf dosbox.conf
Now compare dosbox.conf with your 4000.conf. Any differences besides the cycle settings?
_________________
Reply 4 of 10, by eL_PuSHeR
Editted by eL_PuSHeR
Changed topic title to something more comprehensive...
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 10, by Guest
Compared the two files and the only difference in the change in CPU cycles from 3000 to 4000.
I also tried changing the CPU cycles in the new dosbox.conf to 4000 with no result, DOSbox still started up with 3000 CPU cycles
Reply 6 of 10, by MiniMax
Rank Moderator
Moderator
Hmm... Either I do not understand how DOSBox works on MacOS, or your DOSBox is sick since it refuses to obey the changed cycles setting!
Try this: Search for a file named .dosboxrc (dot dosboxrc, most likely in your home directory). That is an alternative name for the config file.
_________________
Reply 7 of 10, by MiniMax
Rank Moderator
Moderator
@Guest - when you launch DOSBox, how many windows do you get? 1 or 2? Do the second window list which config file DOSBox is using?
_________________
Reply 8 of 10, by Guest
.dosboxrc dosen't exist. I tried renaming my modified config file that but OS X wouldn't let me saying that files beginning with a "." are reserved for the system, and my UNIX is too rusty to try renaming it from the terminal.
I only get one window when I launch DOSbox, the DOSbox window itself, looking at me all smug with it's 3000 CPU cycles...
Reply 9 of 10, by MiniMax
Rank Moderator
Moderator
@Guest - can you modify/add command line parameters to your DOSBox.app? There are some options to have DOSBox redirect some of its status messages to a file (on Windows these messages usually go to a secondary window). Check the DOSBox ReadMe. I think the option is -noconsole and the files are names stdout.txt and stderr.txt.
Unix rename:
$ mv old-filename new-filename
Finally, there is frontend for DOSBox on MacOS. PetitDOSBox or something. Perhaps if you can find a forum that caters for uses of that MacOS frontend, they can help you with the elusive dosbox.conf ??
PS: If you find the cause, and a fix, please, please report back. I would love hear what the problem is.
_________________
Reply 10 of 10, by Guest
try pressing fn(lower left corner of ibook-keyb) + ctrl +f12
you have to use fn to switch to the original function of the key (same for f5 ->reload in fire fox e.g.)
