First post, by Guest
I was wondering if its possible to higher the resolution for the windowed DOSBox? instead of that little window it uses when you load it up.
thanks!
john
Reply 1 of 2, by Snover
'scaler' in dosbox.conf.
Yes, it’s my fault.
Reply 2 of 2, by HunterZ
There's also the hwscale setting, although it only seems to work in certain rendering modes and has varying effects.
