First post, by havli
- Oldbie
I think this list might be useful for those who prefer retro gaming on LCD rather than CRT. And of course LCD should be connected by DVI (if possible) as VGA usually is not good enough. While pretty much any GPU tops out at 2048x1536 @ VGA, DVI is not that simple. So... the plan is to test everything starting with NV10 / R100 all the way up to G80 / R600.
LCD used for testing = Acer XF270HU connected via dual-link DVI. Absolute maximum for this LCD is 2560x1440 @ 144 Hz. 144 Hz is not possible to get using DVI (anything above 60 is difficult actually), so I'll stick to 60 Hz... which should be good enough for retro gaming anyway. 😀
Ati GPU
GPU........... TMDS............................4:3 (5:4) resolution........16:10 resolution......16:9 resolution.........Videocard tested (GPU-Z link)
R200............internal.............................1280x1024...........................?...........................?....................................?
Nvidia GPU
NV40............internal/SIL164CT64................1600x1200................1680x1050..............1920x1080...............GeForce 6800 Ultra 256MB
G70..............internal.................................1920x1440................1920x1200..............2560x1440...............GeForce 7800 GT 512MB
Matrox GPU
I'll update the list with more GPUs later.
