386SX wrote:
Is the FPU someway used by the os to the general tasks?
This is perhaps against popular believe, but I think Windows since 3.1 does use the co-pro to speed up GDI drawing.
I once saw this mentioned in an old computer magazine, where they explicitly stated that this was a major improvement over
Win 3.0 (that issue included a FPU How-To, and benchmarks with/without FPU installed).
386SX wrote:I never really liked the CF solution even if I understand it is quiet similar to the ide interface. Probably cause it sounds "weird" also to knot hear an hard disk running into the case. 😵
But I think I'll need to try it cause this fast ata disk (actually really quiet fast for its time also tried on a vlb/486 config) is quiet noisy I don't know if it's ok or not but somtime it does strange noises..
I know what you mean. I was used to the sound of a DOS machine loading its drivers and stuff.
- Beginning with the floppy drive seek, over the pause himem.sys makes when checking memory, upto the moment when Win 3.1 loads its files..
Anyway, I'm also using CF cards now (but sometimes keep the original drives in the case, for authencity).
That's because in recent years I developed some kind of antipathy against noise.
No idea why, but it now causes me headache and dizziness (too much stress maybe ?)
386SX wrote:
A scsi to sd/cf sound so extreme! 😁
Hey, that's my idea! Just kidding! 😀
You can also try to use a DOM module (disc on memory).
They are quite similar to CF cards, but are made for embedded/industrial use (like some CFs are, too).
Their compatibility is perhaps even better: Pure IDE mode, 512 bytes/sector, SLC memory, 5V compatible, fixed-disk mode, etc.
kixs wrote:With enough memory, Windows accelerator VGA card and possibly CF card for HDD it will run fast. At least the OS by it self.
Absolutely! Some CF cards were slow, though. So I used to benchmark my CF cards with HD-Tune and an USB 2.0 card reader (now USB 3.0).
Important is the access time. Some Cards have 0.1ms (good), while older ones have 10ms (bad).
