First post, by lukeman3000
I'm not sure if this is allowed to be discussed here; if not, I would appreciate being pointed in the right direction for support.
I downloaded the most recent version of the SVN Daum build and am using it with D-Fend Reloaded. Now, however, Space Quest 4 does not go into fullscreen with the overlay render unless I set my window and fullscreen resolution to "original" in D-Fend reloaded. Well, it does enter fullscreen, but the game takes up a small area on an otherwise black screen. Other games seem to work fine with Overlay and user-defined resolutions. When I set the render to Direct3D it seems to work fine.
Additionally, the voice track is slowed down immensely. Other sound effects and the intro music seems to play fine, but as soon as the narration begins (after roger exits the time warp), the voice is very slowed down.
One last thing - do most folks prefer to use SVN Daum builds due to the increased feature set, or do most tend to stick with the official releases?
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
Recent versions of DAUM are a big mess. Don't use it.
Water flows down the stream
