Reply 20 of 25, by Ampera
- Oldbie
wrote:but the only way you'd see the performance increase is with a full 8x AGP slot or the move to PCI-Express
That cannot be further from turth. In fact you will not see any difference in most AGP 4x cards vs 8x cards. And the difference is also neglible between 2x and 4x slots (provided that cards are the same).
The strange part is that the board says it supports 8x speed, but the slot is 4x. Is an AGP 3.0 4x slot 2Gbps?
