First post, by Dimitris1980
- Member
Hello,
since i have not managed to run my roland mt-32 via a soundblaster vibra pnp i am trying another method. I have bought a roland mpu-ipc-t breakout box in a great condition (almost as new) and as i have understood the only thing that i need now is the midi card for the connection. I would like to ask if it necessary to use only the roland mpu-ipc-t card or you can do the job also with others (for instance the mpu-ipc).
Thank you
Dimitris from Greece
- Macintosh LC475, Powerbook 540c, Macintosh Performa 6116CD, Power Macintosh G3 Minitower, Imac G3, Powermac G4 MDD, Powermac G5, Imac Mid 2007
- Cyrix 120
- Amiga 500, Amiga 1200
- Atari 1040 STF
- Roland MT32, CM64, CM500, SC55, SC88, Yamaha MU50
