First post, by Arctic
I am restoring an old HP Kayak XW that I found in an old attic.
The system seems to be working but it refuses to POST without attached fans...
I don't know what the part exactly looks like. It needs 2 pins to connect to the motherboard, but none of my fans are fitting.
This is a database name and description of the part.
HEWLETT PACKARD 5064-6013 FAN/AIRFLOW GUIDE - INCLUDES FAN WITH CABLE AND AIR CharterPoint
I also added a screenshot of the service manual where I encircled the missing part I am looking for.
Could I buy on this website? http://www.montbay.com/bigparts1.htm
Thank you very much 😀
Reply 1 of 4, by meljor
Any 2 wire fan should work.
Reply 2 of 4, by chinny22
So if you plug a standard fan in does it at least post?
Wouldn't worry much about the "airflow guide" just get a nice efficient fan, it will probably have way better air flow then the HP original.
Or add another fan to help airflow in the case
Reply 3 of 4, by Arctic
I have no fan that fits the connector! 😵
Is there a fan expert here on vogons?
Reply 4 of 4, by chinny22
Pic of the connector?
Not saying I'm a fan expert btw!
