Reply 15420 of 59468, by brostenen
Batyra wrote:
About hour ago package arrived :) […]
About hour ago package arrived 😀
It supposed to be Synergy ViperMax... but it happened to be Gravis Ultrasound Extreme - I'm even more happy.
Card came together wit GUS MAX 1.8 with manual and floppy disks adn Media Expert MED3201 (green one) PnP clone.
My version in the early besed on Am78C201KC.
Filnaly my gus collction is complete 😁 now is time for clones, missing revisions, daughterboards and... boxes...
Nice find... Hope you did not pay an arm and a leg for that. 😁
Reply 15421 of 59468, by Batyra
I've boutgh all three at once - so it was easier to negiotiate the price - and I found them on my regional market (so without shipping cost) - so the price was quite small when compared to eBay or Amibay...
My GUS colletion now looks like that:
(photo attached)
I just collect the hardware — others make it run.
Reply 15424 of 59468, by Batyra
Thanks all!
GUS' are my favorite 😀
and Yamaha too... and... Guillemot and... 😁 hehehe
Classic 3.7 is on the way also (the first one with hardware mixer) (bought it for about $60 with shipping and I don't have that revision yet). Now my goal is to find a GUS daughterboard and upgrade some of my GUS'es to box versions...
The moast "beautifull" is definetly Classic 2.4 - without a question. The nicest in use is ACE...
Reply 15425 of 59468, by brostenen
Cool.... That's an awesomme collection. Great job on that.
Personally, I would not mind a full sized GUS classic or something.
Though I fear it will not be used, so for me they are just too expensive.
Useability versus pricetag, as not that many games support it after 94/95.
Reply 15426 of 59468, by Batyra
brostenen wrote:
Cool.... That's an awesomme collection. Great job on that. […]
That's true... those compatibility issuses are annoying... that is why GUS ACE is great - because you use it with some other card... I use with AWE32 with Yamaha DB50XG connected so I have 3 sound standards I can choose in game...
In my collection I focus only on socket 5/7 as base platform... starting with P75 so games supporting GUS it's circa that time period...
Reply 15427 of 59468, by brostenen
More or less... I would use them in 386 to 486 machines instead, as I regard the hayday of GUS as around 1991 to 1993.
That's only aprox a span of 2 years. For 5x86/P75 and faster up to P-II, I would choose SB16's or AWE's.
(or something like that)
Reply 15428 of 59468, by Batyra
brostenen wrote:
More or less... I would use them in 386 to 486 machines instead, as I regard the hayday of GUS as around 1991 to 1993. That's on […]
You're right. P75 is 1994... but I have sentiment I cant resist 😀 so I focus only on Socket 5/7
Reply 15429 of 59468, by jheronimus
meljor wrote:
5,5x multi is an undocumented setting on some boards and can often be found and used. The 6x multi you get by selecting the 2x m […]
5,5x multi is an undocumented setting on some boards and can often be found and used. The 6x multi you get by selecting the 2x multi. The amd will ''see'' this as 6x internally.
On this page there is a bios for that board with support for the mobile k6+ cpu's: http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
IMPORTANT: make sure the board has the right (switching) voltage regulator that can handle the v3 3000 agp. Some boards have that problem and it can damage the card or the board or just be unstable/not post, these have a linear voltage regulator. If the regulator is too weak you can use up to regular TNT2,voodoo banshee or maybe v3 2000.
No tnt2 ultra, Highend Geforce or v3 3000, or stick to pci cards.
Yeah, well, the board did boot with the V3, but the AT keyboard just doesn't work. The motherboard detects all the drives, checks the memory all right and then gives me a CMOS error and doesn't react to any keypress at any point during this process. I've tried different keyboards, different batteries, tried resetting the CMOS — nothing. I've googled keyboard issues with this board and looks like dead AT controller is a pretty common issue that can't be solved without some soldering skills (of which I have non).
MR BIOS catalog
Unicore catalog
Reply 15430 of 59468, by 386SX
I bought a Athlon Thunderbird 1400/133. My power supply is not saying thank. 😁
Reply 15431 of 59468, by vlask
Got some medical use mystery cards (radiology)....sadly Eizo have driver download only for registered users and cannot find any info for Fuji...
Eizo VREngine/SMD5-PCI
Fuji DVI01?
and as bonus i got one card with easy identify but quite unusual bus....
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 15432 of 59468, by tikoellner
Nowadays Batyra totally dominated Polish thrift market for ISA soundcards. 😵 Kidding.
I have my humble purchas to show. Absolutely nothing special (386sx-40|), but just look how small this guy is:
Reply 15433 of 59468, by Batyra
😁 just a few lucky shots... that's all... I promise it won't happen again soon... I'm broke now 😵
Reply 15434 of 59468, by yawetaG
These likely are interface cards for driving the imaging hardware used for taking X-rays. They probably can only be used together with the imaging hardware and software, which due to the radiation used require special permits and safety measures, and anyway would be completely out of reach for a normal consumer due to their price (starting at at least US$ 10,000...).
The more interesting imaging solutions for computer enthusiasts are those used for normal microscopy. These usually use a firewire card coupled with a special high-resolution camera and specialized imaging software, and mount to a normal microscope using an adapter.
Reply 15435 of 59468, by kanecvr
The Eizo VREngine uses an ATI, nvidia or Matrox chipset - depending on age and version. generic drivers will work, but it won't be anything special. The computer built into the phillips based italian x-ray machine we use at my mon's radiology clinic uses an odd nvidia quadro 2000D with a 2gb!!! framebuffer (custom card for phillips?) alongside some dedicated PCI-E hardware witch is hooked up via an internal flex cable to the quadro card adn receives input from the x-ray imaging sensor in the machine trough a Vesa enhanced video connector . The computer itself is a LGA 1366 xeon running at 2.6 GHz (basically an i7 920) with 12GB of ECC DDR3 ram (originally had 6 in 2011 when it was new but I upgraded it to 12). I recently moved the OS to an SSD because the particle generator kept messing with the magnetic disk drives, even tough they are very well screened and the computer is not in the same room as the emitter (it's actually behind an 80cm lead screened wall).
The second card is some sort of accelerator witch I believe would be connected to the VRengine, either externally trough the DVI-like ports, or internally via flex/ribbon cable like in the case of my Quadro 2000D.
Take the heatsink off and see what's under it, or plug it in, install aida64 and google the hardware ID, but don't expect anything special. In your case the PCI cards seem to use a matrox chipset, probably a G500/G550, and the blue PCI-E card is a simple generic display adapter, either a FireGL V3300 or a Radeon HD 2400 PCI.
Reply 15436 of 59468, by Matth79
vlask wrote:
Got some medical use mystery cards (radiology)....sadly Eizo have driver download only for registered users and cannot find any […]
Looks a possible ... http://www.doubleblackimaging.com/downloads/software/
Reply 15437 of 59468, by kanecvr
The first card looks like a matrox graphics card - the second looks like an "image grabber" - a card that collects data from the medical imaging device it's connected to - be it xray, CT, MRI or even an ultrasound machine - the latter being most likely since it has silicon image chips on it. Did you by any chance pull it out of an ultrasound? Digital x-ray is pretty new, and I don't see how PCI cards would be used for it - as far as I know all image grabber cards for x-ray machines are PCI-E, 2006 onward (since it's about that time that they introduced fully digital x-ray machines) - BUT there are older CT, MRI and ultrasound machines used PCI cards.
Reply 15438 of 59468, by kixs
My recent CPU/FPU purchases amounted to this (and joins the other 200++ cpus in my collection):
None tested so far. But I expect them to work fine 😀
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 15439 of 59468, by Thraka
Picked these up at a local recycling place for free. Also nabbed an ISA IDE controller card there too.
