First post, by boxpressed
Not that we would want to use GM.DLS if we had a choice, but still. I have a few variants of the CMI8738 and noticed that what the driver calls "C-Media MIDI Synthesis" is just a softsynth using the GM.DLS patchset. (I renamed it GS.BAK and ran DXDIAG, which did not play music until I renamed it back.)
Can all PCI sound cards access a softsynth that can use Microsoft's GM.DLS patchset? Or just the models that were specced for it? I notice that it sometimes shows up in the MIDI tab (under Multimedia) as an option but doesn't always.
Reply 1 of 4, by Stretch
The older VXD drivers have an OPL2 MIDI device and a Softsynth device that uses a 3 MB DLSWAVE.DAT, but I haven't tested it because the digital output stopped working on my CMI-8738. I have another CMI-8738 with digital but I won't be able to install it until the weekend.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - ESI Maya22 USB
Reply 2 of 4, by boxpressed
That's interesting. My drivers are VxD, but nothing happens when I select FM synth in the DOS games, and there's no FM option under the MIDI tab. I'll have to find some older drivers if it's true that the CMI-8738 has an embedded OPL3.
Reply 3 of 4, by Stretch
Last VXD with FM Synth I could find: http://web.archive.org/web/20060117220544/htt … w9x191cfull.zip
Last VXD: http://web.archive.org/web/20020401230733/htt … _WIN9x_1096.zip
WDM: Never used except for dogbert's unofficial CMI WDM driver http://code.google.com/p/cmediadrivers
Reply 4 of 4, by Kamerat
Tried to see if there's any difference between VxD and WDM drivers?
YouTube channel
