First post, by shiozaki
Building a win98/late dos gaming pc.
i have two motherboards available to me, a asus p5ld2 rev2 and an Asrock 775i65G.
from my understanding the asus board dose not support ddma, and the only dos sound cards available to me are Aureal AU88x0 cards, is this correct and if so which card should i go after?
the asrock board dose support ddma apparently , but agp gfx cards are more expensive, and i already have a pcie 6800 ultra, if i were to use this board again what card should i shoot for?
thank-you for you help.
Reply 1 of 6, by Kamerat
None of them support DDMA. For the 775i65G your options are PCI Yamaha YMF 7x4 with DSDMA TSR, Aureal Vortex 1/2, Sound Blaster PCI/Live!/Audigy and Forté Media FM801-AU. For the P5LD2 you're limited to PCI Yamaha YMF 7x4 and perhaps Aureal Vortex 1/2.
YouTube channel
Reply 2 of 6, by chinny22
If booting into real dos you also have SoundBlaster's up till the Audigy 2 ZS and the Ensonic PCI 64
A lot of other cards have dos support if you play the game from within Windows.
Edit: Kamerat got in 1st!
Reply 3 of 6, by Stretch
On a 775i65G, I heard sound effects in Warcraft 2 with an ESS Solo 1 PCI using ESFM, but not in Doom or Wolf3d.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - ESI Maya22 USB
Reply 4 of 6, by gdjacobs
Do Yamaha YMF PCI cards have issues with Duke Nukem 2 the same as YMF-71x cards?
Reply 5 of 6, by j^aws
^^ Yes they do. You can use AdLib option, alongside Sound Blaster option, to get those missing effects in DN2. They sound different though.
Reply 6 of 6, by brostenen
I recommend YMF-724, Vortex2 or SB-Live.
