mrau wrote:isnt am3/am3+ backwards compatible with am2 anyway?
I theory yes. But before actually buying a chip and a motherboard, it's a good idea to search for a CPU compatibility list for the board you intend to use.
This is for 2 reasons: First one is that not all boards support the CPUs with the highest TDP (my own AM2 board only supported 95W max, for instance) and reason #2 is to do with the BIOS having a limited amount of CPUs it can support (something to do with microcode or something).
It's actually a good reason to have at least a single older and widely supported test CPU at hand, if only for doing BIOS updates so you can then swap the test with the one you really want to use.
An interesting aspect is that there might be a way to download a BIOS file for the board you intend to use (but is without microcode for the CPU you wish to use with your particular board) and then modify the BIOS file by inserting the required microcode yourself...in theory.
I probably forgot something else, but with AM2/AM2+/AM3/AM3+ it isn't plug and play...well it kinda is if one compares it with the plug and play we're dealing a lot with here on Vogons 🤣
You can plug it (fits mechanically) and it will play most of the time...but it doesn't always mean that it will work right out the box 😜
