First post, by DaveJustDave
The attachment IMG_20170123_181110.jpg is no longer available
I have it working on an RGB monitor, but can't tell if its CGA, EGA, etc (because i don't have a keyboard! aarggh!) I do know it's color, but thats all i can determine without having a working keyboard.
it has connectors for serial and gameport, built in parallel port.
2nd question, whats my cheapest way of getting a working keyboard on this thing? 83 key XT keyboards are super pricey on ebay.
thanks guys
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 1 of 22, by luckybob
tell me about it. I also need one of those keyboards for the 5150 i got last weekend.
First glance it is a JUKO G7-B, but its missing things like composite video out. The chip directly under the bank of resistors, starts with JUKO, can you give us the rest of the numbers?
Reply 2 of 22, by Ampera
A initial glance I want to say it's MDA as they tend to have those parallel ports on them, but you said it's colour.
It's not CGA as a CGA card should have composite out. Not only that, but QFP mounting wasn't much of a thing when CGA was around.
I want to say it's EGA, but a very weird EGA card.
I could also be totally wrong, I mean for all we know it could be a Hercules compatible card. Can you give me the text on all of the major chips on it? I will try to look them up. Also maybe a picture of the back? This is the issue when you give low resolution unfocused images, I can't zoom in and read much.
Reply 3 of 22, by DaveJustDave
thanks for your help! attached as few more pictures (pardon the dampness on some of the chips, i had just swabbed them with rubbing alcohol to clean the dust off)
The attachment IMG_20170123_205908.jpg is no longer available
The attachment IMG_20170123_205904.jpg is no longer available
The attachment IMG_20170123_205835.jpg is no longer available
The attachment IMG_20170123_205831.jpg is no longer available
Reply 4 of 22, by jesolo
Doesn't look like it's a video controller.
Based on what I see, it's a combo mfm/rll hard drive controller with an rs-232 (serial) and parallel port (can't quite make out the shape of the connectors on the side to confirm the latter).
It also has a real time clock built in (the onboard battery might need replacement).
Reply 5 of 22, by DaveJustDave
Its definitely a video controller. Plugged my EGA monitor into it and it puts up a display - which is what makes this a very strange animal.
it has FDD, serial, parallel, and joystick.
Reply 6 of 22, by Half-Saint
Regarding XT keyboards, I see this question all the time. You don't have to buy an XT keyboard! You can just get an old AT keyboard because most of the early ones had a PC/AT or XT/AT switch on the underside. I even have one from the early nineties that has this switch.
Reply 7 of 22, by jesolo
Yes, you're right. I counted the pins now and the connector on the far left is your FDD.
The other two are both more than 20-pin, which tells me it's connectors for serial or otherwise.
Reply 8 of 22, by jesolo
I recently managed to find a switchable XT/AT keyboard myself and it works quite well on my XT.
However, I'm not sure of the availability of these type of keyboards anymore.
Most people who still advertise these pre-Windows 95 keyboards probably don't even know it has a switch on underside (if it is switchable keyboard)
So, you will have to ask the seller of each keyboard to confirm.
Reply 9 of 22, by keropi
Post a pic of what you see on the monitor, my guess is that it is a cga clone on a multi-function card.
Reply 10 of 22, by luckybob
In the image, there are two NEC chips. They are 16K x 4 ram chips. $5 says the the 2-pin white connector at the top of the card is the missing composite connector. In the other connectors on the left, you can clearly see "RS232C-2" Its just a matter of tracing the pins to the control chip to make your own serial cable.
Reply 11 of 22, by Tommaso72
I believe I have the exact same card in my turbo xt. It is a Monochrome, CGA, EGA
G7-B
Juko
8-bit ISA
256 kb video ram
Some had composite out, others did not, which was some what rare. A very nice card. Hope this helps!
Tommaso
Reply 12 of 22, by DaveJustDave
thanks for the responses. Upon closer inspection, i am noticing that just about every connector on this card is missing a pin.
both RS232 connectors are missing the top right pin. game port is missing top right pin.
the floppy controller connector is missing the top right pin - pin 34. I've never seen one with a missing pin before.
If you look closely, it doesn't appear to have been made without the pin - the pin looks like it was cut off flush against the connector.
does this make sense to anyone??
The attachment IMG_20170124_183345.jpg is no longer available
The attachment IMG_20170124_183333.jpg is no longer available
The attachment IMG_20170124_183328.jpg is no longer available
Reply 13 of 22, by Ampera
Yea I'd say EGA too.
Well, I already did, so EGA.
Reply 14 of 22, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
You say you had it working, how about running a diagnostic tool like Checkit?
But it can't be EGA because:
a) no video BIOS
b) has a character ROM on board
c) Newest datecode 1987 - at this time EGA was rather new and needed almost a full size card - unlikely that it would fit into the little chip
d) only 16k DRAM - this leaves only CGA or MDA, but it's too much for the latter.
As was already said it might have a composite out because there is a transistor-resistors group. Clone composite out tends to be disappointing though.
Pins cut off is a method for keying, so you can't plug the ribbon backwards. The ribbon connector would have the matching 'pin hole' closed with a little piece of plastic.
Features of this card:
- Floppy controller (UM8272), guess not suitable for 1.44MB floppies, second crystal missing
- 1 serial port equipped (INS8250 + MC1488 + MC1489 soldered in, non-standard serial ribbon cable)
- option to install a second serial port (empty sockets)
- 1 parallel port (implemented in the ASIC)
- 4-axis game port (NE558)
- battery backed clock (MM58167) - only useful in XT systems, and with a driver
- the video, very likely CGA
1+1=10
Reply 15 of 22, by luckybob
+1 for h-a-l-9000
Reply 16 of 22, by DaveJustDave
Thanks for the insight!
At first I thought the missing pins were for keying but looking at a standard floppy controller pinout , pin 34 seems like it's a required pin. I've never seen a floppy connector missing this pin.
I looked at the connector on the cable and there are no blocked off holes.
Reply 17 of 22, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Pin 34 is not used on the floppy controller of the IBM PC. Later implementations use it as Disk Change/Ready signal.
1+1=10
Reply 18 of 22, by Maeslin
While it wouldn't be an 'original 83 key XT', this little project might prove useful. Allows hooking a normal AT / PS/2 keyboard to an XT computer.
http://hackaday.com/2017/01/21/attoxtkeyboard/
Reply 19 of 22, by luckybob
The converter is a WONDERFUL thing to make. I got lucky and one of my AT keyboards had an AT/XT switch on the underside. So I dont need one. but there are more details here: http://www.vcfed.org/forum/showthread.php?264 … highlight=at2xt
I think there might be some pre-made PCBs available too.
