DOSBox ECE (for Windows & Linux)
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Postby Yesterplay80 » 2017-2-08 @ 07:35
Please post all questions concerning DOSBox ECE in this thread for now on, so we can keep other threads tidy and on topic!
I compiled a build of DOSBox ECE for Linux. Consider it highly experimental, since I only run Linux in a VM, I can't test all the features, because the VM is lacking hardware acceleration. So it would be very nice if someone could run some tests with it. It comes (or should come) with all the features of the Windows build, minus the possibility to select the midi device by name or a part of it. Please download it (link is in my signature), play with it and let me know if something's not working or missing!
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
User avatar
Yesterplay80
Re: DOSBox ECE (Windows, Linux)
Postby filipetolhuizen » 2017-2-09 @ 02:17
Hello, any chance you could include the 128mempatch and Pentium_MMX (for CPU/memory hungry games like Blood and Win9x)? Games like MDK would also take benefit from Pentium_MMX. Also the patch to configure video memory size would be good for Build games.
User avatar
filipetolhuizen
Postby collector » 2017-2-09 @ 04:30
More patches for more instabilities? I really hope that ECE does not go too far astray from mainline DOSBox. DOSBox-X would be a better route for Win9x and MMX. I love that ECE has the patches that increase accuracy but does not go down the path of Daum and get broken by needless bells and whistles.
User avatar
collector
Postby Yesterplay80 » 2017-2-09 @ 13:34
Generally I'm not a big fan of adding things that only a handful of games can make use of, as collector said every patch that adds a new feature might break others, so I rather concentrate on those that all or at least many games can gain profit from.
User avatar
Yesterplay80
Postby filipetolhuizen » 2017-2-11 @ 13:45
The Daum build was working fine just until it merged with doxbox-x.
User avatar
filipetolhuizen
Postby collector » 2017-2-11 @ 17:26
filipetolhuizen wrote:The Daum build was working fine just until it merged with doxbox-x.
A perfect example of why the more minimal approach that ECE currently uses is the way to go. Nothing is stopping you from starting your own fork to add the patches that are important to you.
User avatar
collector
Postby Stiletto » 2017-2-11 @ 19:32
The MAME world has something they call "MAME Compiler 64" (and a few others). Makes patching and compiling a breeze for n00bs on Windows. I'm not generally a fan, but until the next DOSBox releases, maybe the DOSBox community needs something similar so that they're not dependent as much on packagers, only on patch authors to maintain their preferred patches?
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby NewRisingSun » 2017-2-11 @ 20:56
Such a frontend would be toolchain- and platform-specific, especially since DOSBox, unlike the "MAME World", mercifully does not use its own toolchain that is annoyingly redone every couple of months. Most DOSBox patch authors, including myself, provide a compiled Win32 executable of the latest SVN with that particular patch applied, so compilation is not required when just using one particular patch, at least on the Win32 platform. And when it comes to applying multiple patches, the potential incompatibilities between the several patches cannot be properly sorted out by a frontend anyway, only by a competent human packager.
(And if the "MAME World" is doing something a particular way, my gut reaction is to do avoid doing that at all cost.)
NewRisingSun
Postby filipetolhuizen » 2017-2-12 @ 03:34
I'd love to. I guess I keep asking everyone else because of my programming skills total lack.
User avatar
filipetolhuizen
Postby Dominus » 2017-2-12 @ 07:18
It's the most easiest part to further your programming knowledge in a couple of steps...
1. follow the guide on how to compile Dosbox yourself (essentially setting up your own development environment)
2. compile Dosbox from SVN and test that
3. learn how to apply a simple patch
4. learn how to apply a more advanced patch and deal with errors when it doesn't apply (with a text editor going through the changes - since the patch is a text file and the source code is made up of text files, it is simple looking at it and finding the pattern where the patch should have applied to)
5. learn how to add mor dependeny libraries to your development environment for patches that require those
6. have no more time to actually play since you are always busy with 4. and 5.and dealing with the fallout of the builds you offered for everyone else ;)
User avatar
Dominus
DOSBox Moderator
Postby gandhig » 2017-2-12 @ 10:54
Vanilla DOSBox Linux build throws 'error while loading shared libraries: libasound.so.2: cannot open shared object file: No such file or directory'. libasound2 package was showing as already installed.
While trying to run DOSBox ECE under Linux(Ubuntu 16.04 LTS), I'm getting 'error while loading shared libraries: libSDL_sound-1.0.so.1: cannot open shared object file: No such file or directory'. libsdl-sound1.2 (1.0.3-7build1) was not pre-installed. Even after installation the error doesn't go away.
I'm a relatively new linux user. What am I missing?
BTW Windows ECE build works flawlessly, thanks heaps :happy: .
User avatar
gandhig
Location: Unknown...yet. Triangulating inside...Level 1
Postby Dominus » 2017-2-12 @ 11:17
@yesterplay, make a static build of Dosbox for linux, meaning you compile all dependenies into DOSBox, otherwise you run into these above problems.
Especially with SDL_sound which can be compiled against SDL 1.2x or SDL2 on the other systems and thus might not be compatible.
User avatar
Dominus
DOSBox Moderator
Postby Yesterplay80 » 2017-2-12 @ 14:05
Dominus wrote:@yesterplay, make a static build of Dosbox for linux, meaning you compile all dependenies into DOSBox, otherwise you run into these above problems.
I thought I'd done that, but it seems I didn't. I'll look into it!
UPDATE: Please check out this binary:
dosbox.tar.gz
(1.21 MiB) Downloaded 259 times
User avatar
Yesterplay80
Postby gandhig » 2017-2-12 @ 15:15
Yesterplay80 wrote:UPDATE: Please check out this binary:
dosbox.tar.gz
Still getting the same error. Is it Ok to run the executable from any user folder?
User avatar
gandhig
Postby Yesterplay80 » 2017-2-12 @ 17:48
gandhig wrote:Still getting the same error. Is it Ok to run the executable from any user folder?
It should be. I'm no Linux pro neither, I installed it only to get DOSBox ECE running. AFAIK it should run from every folder, the problem is that I obviously don't get all the dependent libraries compiled into DOSBox. Does anyone know which switches I have to set when configuring DOSBox?
Code: Select all
LIBS="-lasound -lSDL_sound etc."
obviously didn't work.
User avatar
Yesterplay80
Postby Dominus » 2017-2-12 @ 18:36
No, those are the dynamic links. You need to exchange this with the path to the *.a files of the libraries. You can try this configure option (along with whatever else you pass to configure)
./configure LDFLAGS="-static"
But I'm not a linux guy and on OS X Ihave to rewrite LIBS= manually to use the static libs (because Apple prevents easy static linking).
If you have to do it manually get the SDL libs stuff via "sdl-config --static-libs" (or similar sdl-config -h should tell you).
User avatar
Dominus
DOSBox Moderator
Postby Yesterplay80 » 2017-2-13 @ 07:52
OK, I tried the following:
Checked out a fresh SVN of DOSBox
ran /autogen.sh
ran ./configure LDFLAGS="-static-libgcc -static-libstdc++ -s"
ran sdl-config --static-libs, which resultetd in the following output:
Code: Select all
-L/usr/lib/i386-linux-gnu -lSDL -lpthread -lm -ldl -lasound -lm -ldl -lpthread -lpulse-simple -lpulse -lX11 -lXext -L/usr/lib/i386-linux-gnu -lcaca -lpthread
made the following changes to the file "makefile":
Code: Select all
LIBS = /usr/lib/i386-linux-gnu/libSDL.a /usr/lib/libasound.a /usr/lib/i386-linux-gnu/libm.a /usr/lib/i386-linux-gnu/libdl.a /usr/lib/i386-linux-gnu/libpthread.a /usr/lib/i386-linux-gnu/libvorbisfile.a /usr/lib/i386-linux-gnu/libvorbis.a /usr/lib/i386-linux-gnu/libogg.a /usr/lib/i386-linux-gnu/libpng12.a /usr/lib/i386-linux-gnu/libz.a /usr/lib/i386-linux-gnu/libSDL_net.a /usr/lib/i386-linux-gnu/libSDL_sound.a /usr/lib/i386-linux-gnu/libX11.a /usr/lib/i386-linux-gnu/libGL.a
and
Code: Select all
SDL_LIBS = -L/usr/lib/i386-linux-gnu -lSDL -lpthread -lm -ldl -lasound -lm -ldl -lpthread -lpulse-simple -lpulse -lX11 -lXext -L/usr/lib/i386-linux-gnu -lcaca -lpthread
Compiled and got a DOSBox binary the same size as before. Running "ldd dosbox" also resulted in the same dependencies as before.
I then changed the SDL_LIBS library list to
Code: Select all
SDL_LIBS = -L/usr/lib/i386-linux-gnu/libSDL.a -L/usr/lib/libasound.a -L/usr/lib/i386-linux-gnu/libm.a -L/usr/lib/i386-linux-gnu/libdl.a -L/usr/lib/i386-linux-gnu/libpthread.a -L/usr/lib/i386-linux-gnu/libvorbisfile.a -L/usr/lib/i386-linux-gnu/libvorbis.a -L/usr/lib/i386-linux-gnu/libogg.a -L/usr/lib/i386-linux-gnu/libpng12.a -L/usr/lib/i386-linux-gnu/libz.a -L/usr/lib/i386-linux-gnu/libSDL_net.a -L/usr/lib/i386-linux-gnu/libSDL_sound.a -L/usr/lib/i386-linux-gnu/libX11.a -L/usr/lib/i386-linux-gnu/libXext.a -L/usr/lib/i386-linux-gnu/libGL.a -L/usr/lib/i386-linux-gnu/libcaca.a -lpulse-simple -lpulse
, leaving only the shared libraries for pulseaudio and replacing everything else wth static libraries.
But even now the resulting binary is only 3,7 MB and still has all the dependiencies from the shared libraries:
Code: Select all
   linux-gate.so.1 =>  (0xb77c7000)
   libSDL_sound-1.0.so.1 => /usr/lib/i386-linux-gnu/libSDL_sound-1.0.so.1 (0xb775f000)
   libasound.so.2 => /usr/lib/i386-linux-gnu/libasound.so.2 (0xb7649000)
   libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb762b000)
   libSDL-1.2.so.0 => /usr/lib/i386-linux-gnu/libSDL-1.2.so.0 (0xb7589000)
   libpng12.so.0 => /lib/i386-linux-gnu/libpng12.so.0 (0xb755e000)
   libz.so.1 => /lib/i386-linux-gnu/libz.so.1 (0xb7543000)
   libSDL_net-1.2.so.0 => /usr/lib/i386-linux-gnu/libSDL_net-1.2.so.0 (0xb753d000)
   libX11.so.6 => /usr/lib/i386-linux-gnu/libX11.so.6 (0xb73f1000)
   libGL.so.1 => /var/lib/VBoxGuestAdditions/lib/libGL.so.1 (0xb730f000)
   libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb72ba000)
   libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb7104000)
   /lib/ld-linux.so.2 (0x80027000)
   libmikmod.so.3 => /usr/lib/i386-linux-gnu/libmikmod.so.3 (0xb70b9000)
   libvorbisfile.so.3 => /usr/lib/i386-linux-gnu/libvorbisfile.so.3 (0xb70ad000)
   libFLAC.so.8 => /usr/lib/i386-linux-gnu/libFLAC.so.8 (0xb704d000)
   libogg.so.0 => /usr/lib/i386-linux-gnu/libogg.so.0 (0xb7044000)
   libspeex.so.1 => /usr/lib/i386-linux-gnu/sse2/libspeex.so.1 (0xb701f000)
   libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb701a000)
   librt.so.1 => /lib/i386-linux-gnu/librt.so.1 (0xb7010000)
   libpulse-simple.so.0 => /usr/lib/i386-linux-gnu/libpulse-simple.so.0 (0xb700a000)
   libpulse.so.0 => /usr/lib/i386-linux-gnu/libpulse.so.0 (0xb6fb0000)
   libXext.so.6 => /usr/lib/i386-linux-gnu/libXext.so.6 (0xb6f9b000)
   libcaca.so.0 => /usr/lib/i386-linux-gnu/libcaca.so.0 (0xb6ed1000)
   libxcb.so.1 => /usr/lib/i386-linux-gnu/libxcb.so.1 (0xb6eaa000)
   VBoxOGLcrutil.so => /usr/lib/i386-linux-gnu/VBoxOGLcrutil.so (0xb6df9000)
   libXcomposite.so.1 => /usr/lib/i386-linux-gnu/libXcomposite.so.1 (0xb6df5000)
   libXdamage.so.1 => /usr/lib/i386-linux-gnu/libXdamage.so.1 (0xb6df1000)
   libXfixes.so.3 => /usr/lib/i386-linux-gnu/libXfixes.so.3 (0xb6dea000)
   libopenal.so.1 => /usr/lib/i386-linux-gnu/libopenal.so.1 (0xb6d72000)
   libvorbis.so.0 => /usr/lib/i386-linux-gnu/libvorbis.so.0 (0xb6d46000)
   libpulsecommon-8.0.so => /usr/lib/i386-linux-gnu/pulseaudio/libpulsecommon-8.0.so (0xb6cbe000)
   libjson-c.so.2 => /lib/i386-linux-gnu/libjson-c.so.2 (0xb6cb2000)
   libdbus-1.so.3 => /lib/i386-linux-gnu/libdbus-1.so.3 (0xb6c57000)
   libslang.so.2 => /lib/i386-linux-gnu/libslang.so.2 (0xb6b2b000)
   libncursesw.so.5 => /lib/i386-linux-gnu/libncursesw.so.5 (0xb6af6000)
   libtinfo.so.5 => /lib/i386-linux-gnu/libtinfo.so.5 (0xb6ad3000)
   libXau.so.6 => /usr/lib/i386-linux-gnu/libXau.so.6 (0xb6acf000)
   libXdmcp.so.6 => /usr/lib/i386-linux-gnu/libXdmcp.so.6 (0xb6ac7000)
   libsystemd.so.0 => /lib/i386-linux-gnu/libsystemd.so.0 (0xb6a39000)
   libwrap.so.0 => /lib/i386-linux-gnu/libwrap.so.0 (0xb6a2f000)
   libsndfile.so.1 => /usr/lib/i386-linux-gnu/libsndfile.so.1 (0xb69b6000)
   libasyncns.so.0 => /usr/lib/i386-linux-gnu/libasyncns.so.0 (0xb69af000)
   libselinux.so.1 => /lib/i386-linux-gnu/libselinux.so.1 (0xb6988000)
   liblzma.so.5 => /lib/i386-linux-gnu/liblzma.so.5 (0xb6962000)
   libgcrypt.so.20 => /lib/i386-linux-gnu/libgcrypt.so.20 (0xb68b3000)
   libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb6896000)
   libnsl.so.1 => /lib/i386-linux-gnu/libnsl.so.1 (0xb687b000)
   libvorbisenc.so.2 => /usr/lib/i386-linux-gnu/libvorbisenc.so.2 (0xb67ee000)
   libresolv.so.2 => /lib/i386-linux-gnu/libresolv.so.2 (0xb67d5000)
   libpcre.so.3 => /lib/i386-linux-gnu/libpcre.so.3 (0xb6760000)
   libgpg-error.so.0 => /lib/i386-linux-gnu/libgpg-error.so.0 (0xb674a000)
Btw, why is there a dependency from libFLAC in vanilla DOSBox?
User avatar
Yesterplay80
Postby Dominus » 2017-2-13 @ 08:07
Did you change both makefiles (root and /src)? Did you try with the LDFLAG I wrote (just -static)?
Flac dependency comes from SDL_sound. You need to strip SDL_sound off all dependencies you don't need.
User avatar
Dominus
DOSBox Moderator
Postby Yesterplay80 » 2017-2-13 @ 08:32
Dominus wrote:Did you change both makefiles (root and /src)? Did you try with the LDFLAG I wrote (just -static)?
No, just the on under root. Now it seems to try to compile using the static libraries but results in a lot of errors, I'll try to use only the static libraries for the SDL stuff for the beginning.
User avatar
Yesterplay80
Postby Dominus » 2017-2-13 @ 08:50
yes, this seems a bit complicated. it really shouldn't pull in all of the system dlls. Very problematic are the Virtualbox stuff. This shouldn't really be in at all.
As a rough guideline, my OS X patch for the makefiles looks like this
Code: Select all
--- ./Makefile
+++ ./Makefile
139c139
< LIBS = -lSDL_sound  -L/opt/i386/lib -lSDLmain -lSDL -Wl,-framework,Cocoa -lpng -lz -lSDL_net -framework OpenGL -framework CoreMIDI -framework AudioUnit -framework AudioToolbox
> LIBS = -L/opt/i386/lib /opt/i386/lib/libSDLmain.a /opt/i386/lib/libSDL.a -Wl,-framework,OpenGL -Wl,-framework,Cocoa -Wl,-framework,ApplicationServices -Wl,-framework,Carbon -Wl,-framework,AudioToolbox -Wl,-framework,AudioUnit -Wl,-framework,IOKit -framework CoreMIDI /opt/i386/lib/libpng.a /opt/i386/lib/libz.a /opt/i386/lib/libSDL_net.a /opt/i386/lib/libSDL_sound.a /opt/i386/lib/libogg.a /opt/i386/lib/libvorbis.a /opt/i386/lib/libvorbisfile.a /opt/i386/lib/libvorbisenc.a
155c155
< SDL_LIBS = -L/opt/i386/lib -lSDLmain -lSDL -Wl,-framework,Cocoa
> SDL_LIBS = -L/opt/i386/lib /opt/i386/lib/libSDLmain.a /opt/i386/lib/libSDL.a -Wl,-framework,OpenGL -Wl,-framework,Cocoa -Wl,-framework,ApplicationServices -Wl,-framework,Carbon -Wl,-framework,AudioToolbox -Wl,-framework,AudioUnit -Wl,-framework,IOKit
--- ./src/Makefile
+++ ./src/Makefile
143c143
159c159
(all the framework stuff is OS X specific system stuff, so please disregard :))
User avatar
Dominus
DOSBox Moderator
Next
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 3 guests
