First post, by percy
i am using ESPON-LQ2170, THX!
Reply 1 of 6, by eL_PuSHeR
I think you need some DOSBox build that comes with printing enabled. You may also need to create a new .conf file for DOSBox and edit parameters there. 😎
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 6, by eL_PuSHeR
config -writeconf dosbox.conf
Type this inside DOSBox. Then exit and edit dosbox.conf if needed.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 6, by Guest
hahaa... sorry! how to edit dosbox.conf to setup printer? ^^" THX!
Reply 5 of 6, by eL_PuSHeR
I don't believe you have never editted a file in your life. Use the Notepad, Luke. 😁
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 6, by Freddo
No official release so far have printer support, do they? The parallell port isn't emulated, I belive.
