Freeway LedgerMaster
First post, by Garlic
Hi All.
I'm a Newbie to DosBox.
Anybody still using Freeway LedgerMaster ?
It's an Accounting Package.
Thanks.
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
DOSBox is designed for gaming.
You can try to use it, but don't surprised if it doesn't work. Just don't blame us 😀
Water flows down the stream
Reply 2 of 3, by Jorpho
You should probably look at vDosPlus instead if you haven't already.
Reply 3 of 3, by Garlic
Many thanks for the quick response.
LedgerMaster does run in DosBox but sometimes a bit sluggish, this is not a problem.
I'll give vDosPlus a try also.
I am running DosBox on a selfbuilt Win7 64bit PC.
Once again, many thanks.
