Reply 20 of 33, by Ampera
- Oldbie
wrote:Mistakes happen. Don't be an idiot and buy a hard adapter for the same price of none hard one.
It's a mistake most of us have never made. Hey, at the same time, you need to stop using ALL of your USB sticks. They are long, and they can bend ports. Heck I busted a WLAN adapter once. All of them HAVE TO BE ON EXTENSIONS otherwise you will RUIN YOUR COMPUTER. All dongles HAVE TO GO. While we are at it we are at it, you ALL have to use caddy CD drives because the trays ARE LONG AND EASY TO BREAK.
A hard adapter is by NO means the weakest point of the computer. You REALLY need to wrench them to get anything out of it, ESPECIALLY on DIN and DSUB/DB connectors. Both will work fine, and as long as you don't start ripping your cords every which way, there is 0 issue.
You can feel safer with a cable adapter, but don't go to people saying how it's gonna bust up their computer when it really isn't. You can break a port with a regular cable too! Give it a good yank, and bye bye port. Heck, how about destroying cards? Locking VGA/DVI connectors are terrible because if like most people you like to throw your monitors across the room, the VGA/DVI cable may rip the card apart.
