7-Zip Benchmark, DOS Edition
Reply 40 of 55, by Standard Def Steve
Carlos S. M. wrote:
Added multiple AMD K8 and K10 based CPUs to the list, AMD K8 destroys Intel Netrust in DOS, aparently, AMD K10 is clock per clock slower than AMD A8 in 7-Zip DOS when it comes to decompressing though
Everything destroys Netburst, and not just in DOS. 😁
"A little sign-in here, a touch of WiFi there..."
Reply 41 of 55, by Carlos S. M.
Well yeah, but not with massive difference 🤣 like on these results
Reply 42 of 55, by Carlos S. M.
Added some Pentium 4s using a QDI Platinix 2A (Intel 845 SDRAM), the SDRAM memory made the P4 even slower compared to Pentium III
Reply 43 of 55, by clueless1
I added a P4 2.53, P3 933, and POD200MMX on a SiS 530 motherboard. Interesting to see 200MMX results with various L2 caches:
MVP3 with 1024KB L2
SiS 530 with 512KB L2
Triton with no L2.
All three are within 2.5% of each other on the Decompress (integer) score. It's on the Compress (memory/cache subsystem) that the differences show.
-In Compress, the SiS 530/512KB is 23% faster than the Triton/0KB
-In Compress, the MVP3/1024KB is 15% faster than the SiS 530/512KB and 42% faster than Triton/0KB.
That leads to a MIPS advantage of 11% going from 0KB to 512KB and 17% going from 0KB to 1024KB. Going from 512KB to 1024KB improves MIPS by 5.6%.
Reply 44 of 55, by Carlos S. M.
Added multiple Socket A/462 CPUs, 1 Duron 700, 1 Athlon 1.2 GHz (FSB 200) and a bunch of Athlon XPs (there two Semproms as well, but they are just rebranded Athlon XPs), Clock speed matters more than FSB speed aparently, my Athlon XP 3000+ (2.1 GHz/FSB 400) loses to my Athlon XP 3000+ (2.16/FSB 333) due to the clock speed advantage, also Athlon XP losts to the Athlon 64 clock per clock in both compression and decompression
Reply 45 of 55, by Carlos S. M.
clueless1 wrote:
I added a P4 2.53, P3 933, and POD200MMX on a SiS 530 motherboard. Interesting to see 200MMX results with various L2 caches: MV […]
MVP3 with 1024KB L2
Triton with no L2.
I have an old Packard Bell with an Intel 440VX based board, it has 256 KB L2 acording to some specs, maybe, i could give a try to that system
Reply 46 of 55, by clueless1
I added a column at the end, "MIPS per Mhz" that might be fun to use when comparing.
Reply 48 of 55, by Carlos S. M.
Seems like this thread is dead, i need to wrtie a floppy disk again and bench systems again with the DOS version. My floppy with the 7z benchmark went bad + i had too much classwork, so this why i haven't done many sumbits recently
Reply 49 of 55, by clueless1
Must not be as interesting as the Windows 7-zip benchmark. I've already submitted all my systems. Thanks for all your contributions. 😀
Reply 50 of 55, by Carlos S. M.
Added results from a Duron 1000 and an Athlon XP 2600+ using an ECS K7S5A motherboard
Reply 51 of 55, by Carlos S. M.
Added results from an Athlon XP-M 2400+ in multiple clocks, XP 2600+, both XP 3000+s and XP 3200+ in an MSI K7N2 (nForce 2) motherboard, it seems to be barely faster than my MSI KT6V-LSR (VIA KT600) i used in previous tests, although the K7N2 refussed to boot with my Durons
Reply 52 of 55, by clueless1
The database is a bit sparce with slower systems. If anyone has 286-class, 386-class, 486-class or Pentium-class systems set up, would you mind benchmarking and adding your results to the Google spreadsheet in the first post? Instructions are in that first post, it only takes a few minutes. Well, it might take longer on a 286 or 386. In fact, I'm not even sure this benchmark runs on a 286, I don't have one to test on. Thanks guys.
Reply 53 of 55, by Carlos S. M.
i only got more Pentium and 486 systems. i Still have a Pentium MMX system Packard Bell (Packard Bell OEM board, Intel 430VX 256 KB cache), a socket 7 Pentium MMX i rescued from the trash recently (MS-5129, Intel 430VX 512 KB cache), a dual socket 7 system with dual MMX 233 (GA-586DX, Intel 430HX 512 KB cache), a 486 DX2 50 i rescued from the trash as well, but i need to upgrade the RAM since it only has 4 MB RAM (OPTI 495/493) also a Toshiba Tecra 750DVD i need to check the specs
None of these systems were benched because i didn't have them before except for the Packard Bell
Reply 54 of 55, by robbo007
The best compression I've seen on MSDOS 😀
Is it possible to create multiple volumes with a self extractor combined? It seems to create the .exe and multiple archives but won't let me decompress them.
Regards,
Reply 55 of 55, by Yoghoo
Added an entry as well for an AMD K6-2 500AFX CPU running at 450Mhz (75*6).
Also got the the error that cwsdpmi was needed (with Dos 7.1 from Windows 98SE). Running with either himem or XMS didn't help. It ran with a Dos prompt under Windows 98SE though. Eventually downloaded it from https://sandmann.dotster.com/cwsdpmi/. Only dwsdpmi.exe is needed from that zip file. After that it ran without problems.
