Reply 20 of 22, by Jade Falcon
wrote:wrote:Well?
at least you now got that fancy box 🤣
reflow maybe? not worth it but if u have some soldering station laying around no probs.
Well I told the seller its bad and got a full refund and get to keep the card 😀
I don't really think its worth the trouble to fix. But I'll take a closer look at it. I'll probably take a heat gun to it and if that does not work, pull the Core off to make a key chain and scrap the rest. The parts on this thing are cheaper then cheap. I'd trust a dear PSU about the same amount as I would trust this card. So no pint in taking up time/money to fix it, id only be using it for benching/testing anyway.
