486SX2 vs 486DX4-T100
Reply 40 of 44, by Meister
I thought I have the same computer M4 434S but it turns out it is not quite the same.
I'm missing a few jumpers and the M4 434S has on board audio from OPTi, mine hasn't that is why it seems so clean.
I put in a DX2 66, it sees it as DX2 but CPU speed is still 50MHz. I moved the jumpers in various combinations but still 50.
I have lots of vintages but on this one I could not find any information whatsoever.
I even wrote to Olivetti but got back a standard answer asking me to go to a dealer.
Reply 41 of 44, by FesterBlatz
I have a suspicion that pin header near the CPU socket with the simple two-wire jumper plugged into it is a VRM header. Notice the heavy traces and largish bypass caps in the same vicinity too...
It's possible for 5V CPU's it was simply bypassed with those wire jumpers, and required a 3.3v VRM to be installed when low-voltage CPUs were used.
Reply 42 of 44, by gerwin
Compare it to a Compaq presario 7170 Pentium 90 system board, with UMC chipset as well: ten times more SMD resistors surrounding every chip. I suppose 486 architecture is way simpler, as show by those mini Zida Tomato motherboards.
Reply 43 of 44, by Anonymous Coward
You can consider this as an option to upgrade to DX4:
http://www.ebay.com/itm/Vintage-CPU-Intel-Ove … MUAAOSwr~lYpAug
5x86-133
http://www.ebay.com/itm/Kingston-Turbochip-CP … 0kAAOSwWxNYtMya
http://www.ebay.com/itm/Vintage-CPU-Processor … OMAAOSwopRYmihC
Reply 44 of 44, by Meister
Found the jumper after watching a short presentation clip of an Italian guy on youtube
If someone has the same family of motherboards and want to change the speed from 25 to 33, it's the 2 jumpers in the picture below.
No need for upgrade for me. I have 2x 386, 2x 486, 2x P1, plenty speeds to choose from. 😀
Just wanted to build the best dx2 66 and since this was the best AT case in house, I mounted a 2MB VLB video card instead of the 256kb on board, swapped the factory sound card with a Gravis Ultrasound Classic
and doubled the RAM. It works like a dream.
