Build Log: The Kraken DX4-100
First post, by cj_reha
This is my second build. Today, we're going farther back from Windows 98 and going to roughly the mid 90s with "The Kraken." 😈
Firstly, it's named so because of the massive full tower case it's in. 😲 This thing is something like 3 feet tall! I bought it NIB from eBay for about $100 a few months ago.
I have not yet finished assembling it, but so far these are the specs.
AMD Am486DX4-100 @ 100 MHz, Write Through cache.
64 MB 72-pin FPM RAM
Trident TGUI9440 1 MB VL-Bus video card (Update 3/15/17, Trident card replaced by S3 805 VLB card. Works fine.)
Creative Sound Blaster 16 CT2290 sound card
DTC DTC2278D+ VL-Bus I/O controller
PC Chips M912 v1.7 motherboard
Conner 250 MB IDE hard drive (Gonna add another one soon, this will probably just be the OS and drivers disk, the other for games)
"Turbo-Cool" 300 Watt AT PSU (This thing has a fan speed adjust knob, and at the lowest speed it's freakin' loud and moves a ton of air, at highest, it's a jet engine! 🤣 )
BTC 40x CD-ROM Drive (Primarily used for file transfer since it is a pretty fast drive.)
Creative 4x CD-ROM Drive (Going to be used for games, also the drive hooked to the sound card with the CD audio cable.)
Panasonic 1.44 MB 3.5" Floppy Drive
I plan to put a 5.25" floppy drive in here someday but since I am currently fresh out of working units I will wait a little while and buy one.
"Encore" brand 10Mbps NIC card (may be removed, I probably won't use networking much but it's nice to have in there)
WINMAN MIDIMAN ISA MIDI card (I don't have much MIDI gear so might be removed)
I have formatted the hard drive and all I need to do is get DOS and Windows on this baby 😈
Reply 1 of 41, by Trank
Now thats a tower. I love those gigantic cases. Hopefully you show some benchmarks and the guts when its done.
Reply 2 of 41, by buckeye
The "Kraken" is right!!!
Reply 3 of 41, by jade_angel
That's what I call a skookum case! I loved those, but never could get hold of one back in the day, lucky find that!
Main Box: Macbook Pro M2 Max
Alas, I'm down to emulation.
Reply 4 of 41, by cj_reha
http://www.movesurplus.com/product/10-bay-at- … -power-supply-5
They're even cheaper and there are 30 available 🤣
Reply 5 of 41, by jade_angel
Oh, sweet! That neatly solves a vexing problem!
Reply 6 of 41, by amadeus777999
Remember those cases from way back - solid build.
Reply 7 of 41, by cj_reha
Due to some driver conflicts with the CD-ROM drivers I had to remove the 40x drive, however the quad speed Creative drive works through the sound card. It does slightly bend the sound card down though, but it still works okay afaict
Reply 8 of 41, by cj_reha
Trident VLB card is being replaced with a generic S3 card once it arrives. It seems there was some sort of fatal error while installing video software in Windows 3.1, and any resolution combination I try to use brings up either a black screen or a single pixel which is the cursor. Tried two different variations of the driver, one was for the AGi variant (came with card new in box) and one for the PCI bus variant. Neither worked.
Reply 9 of 41, by x0zm_
That's a shame, hopefully the S3 card does fix it.
Build is looking great. I used to have that case, or something very similar, but had to sell it when I was moving. It was just too big to bring to the new place 🙁
Look forward to seeing it running when it's all done!
Reply 10 of 41, by jade_angel
On the bright side, the S3 should almost certainly turn in better performance. Numbers for reference, from a box I'm putting together.
CPU                           Motherboard                      Graphics card                      RAM                  OS         3DBench  Chris's VGA  Chris's SVGA  PCPlayer VGA PCP SVGA  DOOM Realtics  Quake Lo-res
Am5x86-P75-133 Biostar MB-8433UUD Trident TGUI9680-1 2MB PCI 4x16 FPM MS-DOS 6.22 59.3 42.5 16.4 17.1 6.7 1857 12.8
Am5x86-P75-133 Biostar MB-8433UUD S3 Trio64V2/DX 2MB PCI 4x16 FPM MS-DOS 6.22 72.2 88.9(!) 12.7(?) 18.0 6.4 1681 13.8
I think I've got something mildly hinky there - note the weirdness in the SVGA benchmarks - but the S3 is much faster in most cases
Reply 11 of 41, by JidaiGeki
Liking your build immensely! And as a neat coincidence a couple of weeks back I built a very similar Kraken 🤣 Alas the rear plastic cover on mine has some broken tabs so it's not in place.
The attachment IMG_6619.JPG is no longer available
Non-turbo setting says 'A5' but isn't connected to the motherboard. 7 segments is a bit limiting!
PC Chips M919 Rev 3.2 with 256k cache module
AMD 5x86-133
16MB FPM (2x8MB) - it doesn't seem to like my 16MB FPM sticks but maybe I'll get some 4MB 30-pin stuff later, think it can use both types at once?
Diamond Stealth II S220 Verite 2100 PCI
Adaptec 2940 Fast SCSI PCI
SB Pro CT1600
Seagate Barracuda 2GB (IIRC) - crazy jet engine noisy hard disk
Some 24x CD-ROM
200W Power Supply - just the standard one that came with the case
DOS 6 installed like a charm, but the COM ports are troublesome and my serial and bus mice can't be found - tried a few things, including the original mouse driver that came with the mouse, CTMOUSE and other MS drivers, but no go. Need to stick a serial controller in.
Reply 12 of 41, by cj_reha
Good news: The S3 card came today, and the drivers work perfectly. It's an S3 805, by the way.
All systems are a go, is it benchmarking time? 😀
Just suggest programs I can run and I'll put them on some floppies and run 'em.
Reply 13 of 41, by cj_reha
Benchmarking results.
I used Phil's DOS benchmarking pack, by the way. Evidently the Creative 4X CD-ROM drive reads burned CD-Rs quite seamlessly. It especially loves Verbatim and Memorex brands. 🤣 🤣
Superscape benchmark (3DBENCH): 62.5 FPS
Superscape benchmark (3DBENCH2): 60.8 FPS
Chris's 3D Benchmark: 33.9 FPS (56.5 Chris's score)
Chris's 3D SVGA Benchmark: 8.1 FPS (13.5 Chris's score)
Speedsys: 37.48
Reply 14 of 41, by jade_angel
Wow, those are actually really good numbers!
What's the chipset on the motherboard, BTW?
Reply 16 of 41, by jade_angel
The main reason I'm asking is that your benchmark scores are actually quite a bit above mine, despite a theoretically slower CPU. Time to investigate 😀
Reply 17 of 41, by cj_reha
Specs of the comparative build?
Reply 18 of 41, by cj_reha
I actually think the video card is so fast the hard drive/I/O controller is bottlenecking it, Doom runs very fast but sometimes freezes for a split second while the hard drive loads.
Reply 19 of 41, by jade_angel
My setup is as follows:
CPU: AMD 5x86/133, Write-back cache
RAM: 64MB 60ns FPM (4x16MB)
Motherboard: Biostar MB8433UUD (UMC 8886), 512k L2.
Video: S3 Trio64V2/DX 2MB PCI
NIC: 3Com 3c905C PCI
Audio: Yamaha Audician 32 with Dreamblaster S1
Disk: 4GB industrial CF in adapter
Optical: 48x CD-RW
IO Controller: Onboard, PCI
That's why I'm a bit confused - faster CPU, WB cache... Either I'm doing something really wrong or you're doing something really right, or both!
