First post, by noshutdown
i am setting up such a thing, and ran into some problems that seems to be related to directsound.
the following things managed to run:
3dmark99(d3d).
winquake(software rendering) and quake2(opengl) with sound disabled.
winamp using waveout.
the following operations gives a bsod:
attemping to run quake and quake2 with sound.
winamp using directsound output.
windows media player 6.4, when opening a media file.
bsod message:
a fatal exception 0E has occured at 0028:c11e14b1 in vxd dsound(03) + 00000C6D.
dxdiag crashes, without causing bsod.
i wanna know if you people ever encountered similar problems, or run such programs without any issues. and the version of directx you use in win95? or shall i change a sound card? current sound card is diamond s70, using generic ess1968 driver.
