First post, by Kahenraz
- l33t
The auction says Socket 3 but I'm not familiar enough with pre-socket 7 to confirm. There is a 486 in it but there are unslotted pins around it.
Would someone explain why there are free pins surrounding the 486?
Because those pins are intended for larger chips. I think some POD chips used them, possibly some 5x86 chips. If they have those extra pins, it's a Socket 3 socket, and if the auction says it's Socket 3, it's socket 3 and will accept any 486 chip (MAKE SURE TO SET THE VOLTAGE RIGHT, DX4 USES 3.3 DX-DX2 USES 5)
The extra row of pins is for POD (Pentium Overdrive). All the other s3 chips (including the non-Pentium regular Intel Overdrives) don't use the outermost row.
