First post, by VirtuaIceMan
I've got a copy of the fairly rare/dismal racing game Kraze, by 7Seas/Candella. It was working on Win10 fine last year, but now boots up and does nothing (not even the pre-launch splash screen).
I ran it through Process Monitor and it seems to get so far then just stops.
I don't know if the issue is caused by updated graphics drivers, or, more likely, updated Win10 files.
If you're someone good at analysing these sort of things, send me a PM.
My PC spec: Win10 64bit, i7-4970K (not overclocked), KFA2 GeForce RTX 2070 SUPER, Creative Soundblaster ZXr, 16GB RAM, Asus Z97-A motherboard, NZXT 410 case, ROG Swift GSYNC monitor
Reply 1 of 9, by TheAbandonwareGuy
https://arstechnica.com/gaming/2015/08/window … ys-microsoft-2/
Windows 7 and up were patched to break any game using Securom or a few other disk based DRM's. They literally blocked Windows 10 from loading the Securom driver files. You need to find a no-CD patched game executable. Your on your own on that one though. If the moderators have any issue with me suggesting this by all means remove this post. Given the circumstances I think this falls within the acceptable category seeing as how its the only way to get the game running.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 2 of 9, by VirtuaIceMan
It doesn't use any of those security protection systems. It was working fine, now won't do much. If someone here is knowledgeable in understanding why then that's be useful. AssemblerGames would be a good site to ask, but it's currently down.
Reply 3 of 9, by ZellSF
If it used to work then and doesn't now you need to find out what you changed since then, and I really doubt it was Windows 10 updates. Chances are good that even if you find someone good at analyzing why games don't work they can't reproduce your problem, because it's something specific to your setup other than being at the latest version of Windows 10.
I would also check Event Viewer and see if it logs anything when you try to start the game.
Reply 4 of 9, by BuckoA51
This is bullshit, sadly typical of the tech press these days that's always racing to get stories out before the competition, with little thought for actually fact checking them. SecuROM works just fine in Windows 10, it's Safedisc that is broken.
Even now Google is full of articles claiming Windows 10 patched out SecuROM compatibility, despite it being utter nonsense.
play-old-pc-games.com
Reply 5 of 9, by Jo22
The new security *fixes* for Windows 10 were also backported to Windows Vista and Seven and then silently, automagically installed via Windows Update..
Nice isn't it ? MS really cares for the users. They try to make sure even users of prioer OSes get an equally good experience whenever possible. 😀
https://www.rockpapershotgun.com/2015/09/23/w … -drm-7-8-vista/
Reply 6 of 9, by keenmaster486
This is why I switched to Linux for good.
All of the Windows programs I want to run are too old for Windows 8/10 so I have to run a virtual machine anyway! 🤣 Take that, Microsoft.
World's foremost 486 enjoyer.
Reply 7 of 9, by BuckoA51
and no security update in Linux ever broke compatibility with anything 🤣
Reply 8 of 9, by Destroy
Wow! This is some truly draconian poop.
Very good info to know if wanting to play older games.
MS does note a way to by-pass it here: https://support.microsoft.com/en-us/help/3086 … phics-component
