First post, by =zum=
- Newbie
I was Playing Monkey Island 1 and i hear the sound effect of a door is incorrect for the real one... in version 0.64 (?) version of dosbox this bug will be fixed?
Thanks.
Thanks.
I don't know. It'd be nice if someone who knows what they're doing would re-merge the latest MAME OPL emulation code into the DOSBox CVS though...
It would also be nice if the poster was more exact. I'll check out ScummVM vs DosBox for MI1 tonight....
scummvm is wrong too... the sound is too fast and the sound effects is wrong then.... i try my real OPL2 just now and my suspect was right 😀
You should record the sound from your real OPL2, from DOSBox, and from SCUMMVM and post it here (or the DOSBox bug tracker) and to the SCUMMVM bug tracker. Otherwise, noone will bother to look into it for you. I'm speaking from personal experience here...
ok....just wait some day until i record the effects 😉
bye!
Ok Guys...i've recorded the sound...it's a door in monkey 1 floppy version..opening e closing. (same sound in indy3)
Sorry for the bad recording of OPL2 Genuine and Scummvm Emulation but i have a stupid microphone 😜
I also post it on bug tracking of dosbox and scummvm 😉
Here we Begin with Genuine OPL2
One thing is for sure: The three of them sound totally different.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Yes! That's beacuse i created this topic...wait...i've discovered another leak in AdLib Emulation.....Exactly, this time i've listen the difference between Real OPL2 and Dosbox and Scummvm (same sound in this way) on the Scummbar Theme of MI1....
This time i've hear some metallic sound that not appears in the original track!
Listen:
I finally get this stupid sound by my old computer!
It's not like anyone will bother even if he does. I'm speaking from personal experience here... (*scnr*)
Oh please not another "we need a redboost control" thread.
Why not? You'll use it anyway to ask questions about Tandy sound or lecture people about being deferential towards you.
Actually, I was referring to Incorrect FM in Commander Keen 6.
> Actually, I was referring to ...
If there's no reply then this *might* mean that nobody has found
a solution yet, not that something is ignored or whatever.
Don't know what you want with the first part of your post.
well I'll take a look when I work on that part.
Plan to rewrite that.
Water flows down the stream
I Just recorded the sound of the door by real adlib using a output-input connecter but i founded some problems while hosting it, as soon i return from rome i can retry hosting it on my own space, just wait to 18th
