First post, by sandprogramer
Using dosbox for the first time. Mounted my drive and can list the program code, but when I try the "run" command, it just states "syntax error". Any recommendations?
Reply 1 of 4, by Jorpho
You're going to have to be a lot more detailed than that, as I have no idea what you're talking about. Are you trying to run a BASIC program or something? If you're using an old .bat file, then DOSBox may not be appropriate.
It may be appropriate to follow the 60 Seconds Guide.
60 seconds guide to getting your game to run in DOSBox
Reply 3 of 4, by Doctor Yuckey
