Red PCB RAM (simm72 or sdram)
Reply 23 of 48, by Batyra
I didn't notice new posts in my topic.
thanks @ajdrenter!
@c0keb0ttle helpled me allready - once again great thanks!
Memory wors great and my socket 7 red mobo sees all 512!
Here some photos.
    353.75 KiB
    466.94 KiB
Reply 25 of 48, by Batyra
Thanks gbeirn!
Yes, as for socket 7 it's quite extraordinary...
Now I bought PC Partner MVP3BS7-954 and I aim do do the "super tiny" socket 7 build... thinkind of small soundcard, and graphic card.
Reply 26 of 48, by Anonymous Coward
Although I hate VIA, I really appreciate what you're doing. There is a certain shade of green PCB that I like...it should be a nice deep glossy green, like what Orchid used on its products. Matching shades of green is hard enough. I can only imagine the headache involved in going red. I remember in the 90s there was this guy who owned a used PC hardware store that collected parts with blue PCB...it was old stuff too. Mostly from the 286 generation.
Reply 27 of 48, by Batyra
I know what kind of gray you mean... I have Tseng et6000 and newly bough AdLib asb 64 wave in this deep green colour... I'll try to look for that kind of motherboard...
Blue PCB socket 7 build seems even more difficult than red... although I didn't knew red s7 mobo existed before I bought this one...
Reply 29 of 48, by meljor
Missing a red cpu heatsink and/or cooler, sorry... you're not done yet!! 🤣 But very nice setup!
(and a red mouse, keyboard, harddisk/harddisk cooler, tower, psu, red wire sleaves, usb card, ide cables, floppy cable)
Reply 30 of 48, by luckybob
This project needs SATA hard drives, usb 2.0 support, and firewire. All in one, convenient card.
https://www.amazon.com/PPA-Intl-Combo-Card-Fi … e/dp/B0028QPLIA
Reply 31 of 48, by luckybob
oh, these cards work very good for networking: https://www.newegg.com/Product/Product.aspx?I … N82E16833166002
Reply 32 of 48, by brostenen
#Batyra:
Have you thought of naming this build, something that refers to the red colour? Like "The Devil", "Angry old man" or something just a bit political, like Stalin or Lenin?
Reply 33 of 48, by Anonymous Coward
For a network card, you can also consider 3com 3C508-TPO/TPC if you want to use era correct parts. At least one version comes with a red PCB.
Reply 34 of 48, by kenrouholo
Ampera wrote:
lol, that board looks like it's compatible with literally everything. You got two power connectors, two type of RAM slots, 3 types of expansion slots, goddamn.
Not that uncommon with Via MVP3 boards, I don't think. Another is DFI P5BV3+.
Yes, I always ramble this much.
Reply 35 of 48, by brostenen
Yeah.... I had an Epox MVP3C that I sold some time ago.
It had some of the same qualities, such as AT/ATX-Power, Cyrix/AMD/Intel, AGP, PCI and ISA.
Reply 36 of 48, by peklop
I have more tips for:
Expertcolor MED3931 to the second ISA slot if you want ISA IRQ/DMA war with ViperMax.
or GUS PnP, of course
Tips for red PCI card
red PCI ATA133+SATA controllers are comon if you want connect modern HDDs or SSD
old Pinnacle TV Tuner cards are red
Some ESS and other PCI sound cards were red too
red 3DFX Voodoo or Voodoo2?
many USB 2.0 and Firewire card were red
some PCI diagnostic POST cards are red. Red card with RED segment LED looks good
Red IDE cables were used by MSI
Reply 38 of 48, by luckybob
peklop wrote:
i found red supercombo card with ATA133. SATA/eSATA, USB 2.0 and firefire on single pcb: https://images-na.ssl-images-amazon.co […]
And many IDE to SATA converters are red
*COUGH*
Reply 39 of 48, by gdjacobs
Careful, the SATA chipset on that isn't forward compatible with newer hard drives (I believe SATA3+).
