Reply 160 of 894, by keropi
yes- but it will take some time because this time the card is getting redesigned and there is a new feature addition 😀
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 161 of 894, by badmojo
Wavetable header??
Reply 163 of 894, by jheronimus
Is there any way to reserve a card? Do you have any idea how much the final version might cost?
MR BIOS catalog
Unicore catalog
Reply 164 of 894, by keropi
At this point there is no way to reserve/preorder , there is no definite timeframe when the card is checked and ready to go , so it is best to avoid unpleasantness.
Cost-wise it will be slightly more expensive, nothing that will scare people away... will it be 5eur? 10eur? 15eur? it won't be more than that though
Reply 165 of 894, by Rackatack
this might be a stupid question, but what will the wavetable header provide if you are able to hook it up to a midi device?
Reply 166 of 894, by DonutKing
badmojo wrote:
Wavetable header??
This pleases me.
You can use a wavetable daughterboard, eg wave blaster, SCD-15, XR385... without relying on another sound card that might have bugs.
Reply 167 of 894, by keropi
The ability to use wavetable daughterboards , maybe someone does't want to go external, doesn't like the clutter, already has daughterboards to use , avoind hanging notes as DK mentions above, etc etc
Functionality-wise it will be the same as the MPU401-AT .
Reply 168 of 894, by badmojo
Yes that's a very cool development over there indeed keropi 😎
Reply 169 of 894, by keropi
thanks!
we also moved from DIP components to SMD ones (except the Z8 , we don't touch this so we don't break any compatibility) , card should be a little larger than a XR385 😀
still there is work and testing to be done, it's all on paper (ok screen 🤣) atm
Reply 170 of 894, by Jepael
Nice - Let me know if you want a schematic review on that 😀
Reply 171 of 894, by keropi
sure, ideas for improvements are always welcome 😀
Reply 172 of 894, by Rackatack
I understand, It makes a lot of sence, and I forgot that some cards didn't have the wavetable header ...
There are a lot of good and "cheap" options for general midi, the dream blasters are amazing.
Would you be able to use a midi daughterboard together with an external MT-32 for example?
Reply 173 of 894, by keropi
Yes ofcourse! you can use both wavetable and external midi-out at the same time without issues.
Reply 174 of 894, by gdjacobs
As with multiple modules, doing so would require a mixer.
Reply 175 of 894, by Rackatack
seems a cool way to test and compare two different modules, or to only have the one that sounds best for a game or so.
Reply 176 of 894, by Rackatack
regarding the hanging note bug, I think I'm lucky that I didn't have to suffer from that with my cards, the only time I have that issue is when the game crashes, or when I "force quit" the game.
Reply 177 of 894, by bjwil1991
Wait... WaveTable and MPU401 combined on one card? That's amazing! Would the card have an output connector to hook up to speakers or a sound card? I'm planning on buying the card in the future, and purchase a WaveTable daughter board.
Reply 178 of 894, by keropi
^ yes, both working at the same time and ofcourse there will be at least a 3.5" stereo jack that will output the daughterboard's audio.
Reply 179 of 894, by Rackatack
looking forward to it! any idea for a release? summer or next christmas?
