Missing heatsink
First post, by candle_86
So I have an ASUS TUV4X board but the northbridge heatsink is missing, I checked my spare's I have none that fit, any suggestions can the VIA Apollo PRo 133T run without a heatsink, can I use my artic alumina adhesive to attach a heatsink from say a dead TNT2 to it, what are my options?
Reply 1 of 6, by Jade Falcon
Rank BANNED
BANNED
I'm betting you won't need a heat sink if your not overclocking and have good case air flow. But I'd wait for others to comment first.
That being said I'd buy the right heatsibk for the board and not use adhesive. That is unless your low on funds and all ready have the stuff to do it.
Reply 2 of 6, by candle_86
It's the board from the recycler I tested for post and it posts ill install 9x this weekend and do a stability test
Reply 3 of 6, by nekurahoka
If you're not worried about authenticity of the board, any heatsink will do. If it were me, I'd use the one you have from the TNT2. I pull heatsinks from dead hardware specifically for instances like this.
Dell Dimension XPS R400, 512MB SDRAM, Voodoo3 2000 AGP, Turtle Beach Montego, ESS Audiodrive 1869f ISA, Dreamblaster Synth S1
Dell GH192, P4 3.4 (Northwood), 4GB Dual Channel DDR, ATI Radeon x1650PRO 512MB, Audigy 2ZS, Alacritech 2000 Network Accelerator
Reply 4 of 6, by luckybob
Search google / ebay for "zalman northbridge"
Pick one that suits your aesthetics.
Reply 5 of 6, by ODwilly
I second the suggestions for using adhesive with an existing spare heatsink. It is not like the TDP of the VIA Apollo chipset is very high, off the top of my head I would say it is 15 watts max? Well within the thermal design of any dead AGP card or other passive heatsink you may have on hand.
Reply 6 of 6, by candle_86
Alright well the TNT2 on is glued on and nice and square, I'll use some acetone to remove the old glue on it, and possible the paint so I get a nice bare metal look, then adhesive it it to my Apollo Pro.
