Reply 16540 of 52991, by Rhuwyn
TheMobRules wrote:
Rhuwyn wrote:
Two Socket 3 motherboards 1 PCI and 1 VLB. Both untested but I got it for 40 shipped so even if just one works it's a decent deal.
http://www.ebay.com/itm/221981808499
Did you end up getting those Socket 3 boards? If so, the PCI+VLB board (the one on the right in the first picture) seems to be the (in)famous PCChips M919, and it has the custom COAST-like cache module! 😲
Even if the boards are not working, that cache module is very rare, and probably very expensive.
I got them for 40 bucks on an offer. Have not recieved it yet. I hope your right about it being that board.
Reply 16542 of 52991, by Scraphoarder
A couple of MSI MS-6551 arrived to day. With IO shields, not bad. No idea why the seller included the SATA cables..
578.35 KiB
Reply 16543 of 52991, by brostenen
Wonderfull.... P4 with ISA slot. 😜
Reply 16544 of 52991, by dexvx
Was rather surprised to see the a Nvidia ES sample today, so I picked it up. No idea if it works or not. Looks like G72M is a mobile chip (Go 7400/7300/7200 series).
Reply 16545 of 52991, by Gamecollector
Willamette only. Well, maybe Northwoods with the 400 MHz FSB too.
P.S. MBs with 1 unmounted edge still bug me...
Reply 16546 of 52991, by TheAbandonwareGuy
xplus93 wrote:
Found this baby hiding in the CPU section of ebay. Cheaper than the one I was watching and in near mint condition. Popped the service tag into dell support and checked the original build. Supposedly it shipped with a P4 EE 3.4/800. It's a bit off from what the seller described, but I really don't see a reason why anybody would downgrade a CPU.
CPU failure and insufficient funds to replace the original model with another like it. or maybe the CPU was dead when the seller received it and he repaired it with a lower end part due to the price and rarity of the EE.
Reply 16547 of 52991, by TheAbandonwareGuy
dexvx wrote:
Was rather surprised to see the a Nvidia ES sample today, so I picked it up. No idea if it works or not. Looks like G72M is a mo […]
Keep us posted. I've never seen a mobile chipset on a PCI-E card. Sadly, it almost certainly will either require custom drivers not open to the public and at the very least will likely have an unsupported device ID. Where did you even find that? I don't think that stuff is ever suppose to leave the hands of who it originally went to.
Reply 16548 of 52991, by yawetaG
What is the small, silver (aluminum tape?) connector at the top for?
Reply 16552 of 52991, by rein_ein
Bought bundle:
- NEC Multispin 8V
- Pentium MMX 166
- some unknown chip marked "IBM"
- 3dfx Voodoo3 1000
- ATI 3D Rage II+ DVD which is pci
- ESS ES1868F based (SC1868)
- usb controller on ALI M5273 chip
Reply 16554 of 52991, by dexvx
I found it at a local tech surplus shop. Since I work with hardware, the most logical guess that happened is some Nvidia employee/contractor went to dispose of it and literally put it in the wrong bin. Usually there's one bin for scrap/waste that goes to auction or a waste disposal company. The other bin is for confidential materials (like HDD/SSD, pre-production HW) that gets destroyed.
Edit:
Looks identical to the card here (bottom row).
http://www.yjfy.com/Museum/video/G72_ES.htm
Reply 16555 of 52991, by meljor
Finally found a Geforce3 ti500 and i'm very happy with it. It's exactly the same as this picture from google (Asus deluxe version), works like a charm!
20 euro incl. so a very nice deal i think.
    72.33 KiB
Reply 16556 of 52991, by rein_ein
gdjacobs wrote:
I hope you get a chance to try the ESS card!
For sure,i have same card but other revision (2.1) with bit different layout,that came with wavetable daughterboard.
p.s "new" card revision is 1.10
Reply 16557 of 52991, by Skalabala
Soooo JEALOUS!!
Reply 16558 of 52991, by meljor
Soooo JEALOUS!!
🤣 I don't think it will make a difference for the k6-3+ benchmarks... the ti200 is already bottlenecked as far as i can tell.
Reply 16559 of 52991, by kithylin
Was that the one I posted up on ebay a while back in the ebay thread?
