First post, by Rhuwyn
So I'm putting the final touches on my time machine. it consists of a brand new case. Full ATX but compact. A Full size but shallow depth power supply so I could fit the 5 1/4 inch floppy I bought for it in there. a K6-3+ with an Asus P5a amoung other googies. I will most more details in system specs when it's done.
Problem I am running into is the 5 1/4 drive screw holes don't line up. Which is weird because I didn't think they ever changed that. Of course I am likely wrong on that point. I specifically spent way too much money on a drive that was already black in color to match. Also the Bezel is too wide to fit properly without being recessed. Anyone have similar issues? I feel I probably have no choice but the shave off the sides of the bezel and drill new holes to mount it. Unless anyone else has any ideas?
