First post, by dexvx
Assuming the bus is standard (PCI/AGP/PCIe)
Does a MAC edition Radeon/GeForce work on normal PC's? Or is there something in the firmware of the video card that may prevent it?
Reply 1 of 9, by Jorpho
It's been a while since I've read about it, but I'm pretty sure you need to flash the firmware to get it working.
Reply 2 of 9, by jade_angel
Generally it won't work, at least not in Windows or DOS, since those depend on the card's firmware to set it up initially. On a Mac-edition card, that firmware is OpenFirmware fcode or PowerPC machine code, while on a PC-edition card, that's x86 machine code. So, the Mac-edition card's firmware will, at best, not run on a PC. (It may *try* to and freeze the machine at boot, too)
Under Linux and BSD, some Mac edition cards can be used as secondary graphics cards, while some can't - YMMV, and you'll almost certainly have to screw around with it. Anything that tries to touch the firmware/BIOS will not work right while poking the chip directly will. I personally wouldn't bother, and I'd reflash the firmware if you can.
The same thing also applies to PCI cards designed for HP PA-RISC, Itanium, SPARC and Alpha machines.
Main Box: Macbook Pro M2 Max
Alas, I'm down to emulation.
Reply 3 of 9, by candle_86
Sometimes, for instance my Mac Edition HD4870 works fine in PC's, in general the AGP versions don't but the PCI express versions do.
Reply 4 of 9, by jade_angel
Most of the PCIe ones were designed for AMD64 Macs, though, weren't they? If so, they'll have EFI firmware, which should work on a PC with EFI.
Reply 5 of 9, by candle_86
Yes they where all efi ones work on pc
Reply 6 of 9, by yawetaG
The PCI-express bus was never used on PowerPC Macs, only on Intel Macs.
Reply 7 of 9, by candle_86
Your point, he never specified what type of mac, and just an FYI the Intel MAC's still have a diffrent UEFI boot code, its just that Nvidia and AMD ship their cards as cross compataible.
Reply 8 of 9, by jade_angel
The Power Mac G5 had PCIe expansion slots, which is why I asked. (There are also other non-AMD64 machines with PCIe, like the newer IBM POWER machines, HP Itaniums, Sun SPARC servers and the Ultra 25/45 workstations, but the cards made for these aren't anything you're liable to trip over in normal use.)
Reply 9 of 9, by yawetaG
*checks*
Oh, it's only the multi-core systems that have them...didn't know that. 😊
