First post, by Smack2k
- Oldbie
Trying to build a 386DX-33 machine, but running into issue with controller(s) or motherboard(s). Installing the system with the GoTek USB Floppy Emulator and an 4 GB SD Card for a HDD.
I have tested with the 386DX-33 board and a 386SX-25 board along with 3 different Controller cards (all Goldstar Prime 2 chips) and keep having the same order of issues:
Board Powers On fine, does a Floppy Drive seek test and the drive reacts, no errors on the screen. When it finishes POSTing, it attempts to boot from floppy. On both motherboards and all 3 controllers tested I get one of the following:
1. DISKETEE ERROR, Place disk in drive and press any key - This was with the GoTek USB as well as 6 or 7 different Floppy drives. Used known good DOS Boot Disk in the emulator and regular floppy disk
2. Boot Disk starts to run, Get the Starting MS-DOS command, but then stops there and does nothing. Have to power off the system. This was with the GoTek USB as well as 6 or 7 different Floppy Drives and good disks
After many attempts are made with the above issues, eventually the system boots and starts giving FDD Controller errors and goes no further.
So I either have 3 bad controllers or both motherboards are bad....not sure which.
Also, from Phil's video on building a 386 using CF / SD Storage, he entered the details for a 504 MB HDD in the Hard Drive 0 section of the BIOS and then rebooted the machine and booted from floppy with no errors seen on the video. When I put the details into the BIOS for the 504 MB Drive, save and reboot, I get a HDD Controller error everytime (with the 4GB SD Card adapter attached). If I leave Hard Drive 0 at Not Installed, no HDD Controller error on boot but that is expected. This was also seen on both boards and all 3 Controllers...
